Need Your Input About These Headlights
Nobody is going to like them and they have inherent problems.
They are JDM-spec which means the cutoff is on the wrong side and they tend to blind oncoming drivers. They tend to not be sealed too well and spring leaks. They use cheap projectors and the light output is weak.
I also doubt that the halo lighting lasts very long or even works at all on our cars. Plus they tend to look mismatched unless you get black highbeams as well, or if you remove them and repaint the high beam housing black, and then you still have the problem with the fog lights looking mismatched. But ultimately we can't tell you how to spend your money. That's up to you, but very few people seem to like these lights. I'd recommend just leaving the headlights stock an saving your money for something else. An if you simply must have different headlights, spend the money on a proper retrofit, so that the money will go into an upgrade, instead of these aftermarket headlights, which most agree is a downgrade.
Rock-a-Lex
02-28-10 11:42 AM
