SC- 1st Gen (1992-2000)
DIY racing tow strap instead of tie-downs?
Old 02-19-15, 11:53 PM
t2d2
t2d2's Avatar
That's certainly possible. In the unfortunate event I ever put it to the test, I'll be sure to look it over afterward for signs of undue wear and tear.
Old 02-23-15, 09:32 AM
Cleanshots
Cleanshots's Avatar
Originally Posted by t2d2
The seatbelt is metal where it clips in and metal at the exposed portion where the belt loops through. I can't imagine it wouldn't be metal throughout the rest that you can't see, given its safety purpose. You may be right about those other ones not being plastic, though. I looked back at a few and see some of them described as metal even though they look like plastic, so maybe they're coated? Others that look the same don't specify. But I read that the Sparco one which looks the same is plastic... At any rate, there's significantly more metal on the seatbelt buckle than any of those brackets. Just look at the shape and how little material they have around the tapered portion surrounding the bolt hole.
propper tow strap metal part is twice as thick as the metal on the seatbelt..
Old 02-23-15, 11:43 AM
t2d2
t2d2's Avatar
When you say "thick" are you talking depth or width, looking at the bolt hole?
YeA 2jZ
13
07-22-14 03:45 PM
snook
16
08-29-09 05:43 PM
scb71
GX - 1st Gen (2004-2009)
07-07-08 12:47 PM
Christobol
RX - 1st Gen (1999-2003)
02-01-03 04:20 AM
Quick Reply: DIY racing tow strap instead of tie-downs?
