is this a decent price on exhaust work?
I already have axleback mufflers and a not-yet-installed downstream y-pipe for my SC400. I took it to an exhaust shop today to see about getting the rest of it done up, i.e. replacing the center resonator with a 2.5" straight pipe after the cats and first y-pipe, connecting up to my new 2.5" inlet to dual 2.25" outlet y-pipe, and then either tied into the two resonators before the mufflers or replacing them altogether with 2.25" to the axlebacks.
The tech felt it would be best to replace all the narrow tubing from the second y-pipe on back to the axlebacks, as many here recommend. I'm still a bit fearful of that being too loud, but there's only one way to find out... It's already a lot louder than stock with the expanded intake, removed intake resonator, and M2 exhaust. But no one buys a V8 to be quiet.
I've never had exhaust work done before, so I don't know what's considered a normal price for that sort of thing. Obviously, costs vary somewhat by area. The quote was $256, which breaks down to $140 labor (2 hrs), $70 tubing, $20 flanges, $20 shop fees / misc., $6 heat shield clamps (optional, for current vibrations). That's for compression bending, not mandrel.
There's not anything excessive in there, so I'm guessing it's reasonable. The guy seems pretty knowledgeable and is well reviewed.
You can tell a huge difference....for what you are doing aluminized steel is fine...
Aluminized steel exhaust has a thin wall and looks like aluminum...ie dull silver color....very easy to bend and flare
Stainless steel has a thicker wall and looks polished....it is also very difficult to bend stainless steel....usually you just buy mandrel bent pieces....
This stuff sure looked polished. He's got all the heavy duty bending equipment... He figured two 7' sticks ($35 ea) for the dual 2.25" and averaging the extra material out with grabbing a 2.5" scrap from his pile on hand, so I would assume what he's got there is the same material as what he would order. Hopefully it's stainless, otherwise I could have gone with an aluminized steel y-pipe that would have fit a bit easier.
You guys were right, the quote was for aluminized steel. Stainless would add $50-70 to the cost plus a bit more in labor, although he did say he has a stick of 2.5" stainless lying around that would be perfect for the center section and wouldn't need bending. He didn't think it makes much difference one way or the other, though. I'll be going ahead with the work in the next few days. Looking forward to seeing and hearing it!
I don't know if it'll be quite this aggressive, or if I even want it to, but wow:
I was quoted $250 to straight pipe mine staring from in front of the middle resonator. Exhaust shop I took it to is a one man show. He owns the shop and does all the work himself. He had never done an SC before mine and he had to come up with everything on the fly. I had taken my mufflers and mid pipe off months before and they had gotten damaged. So he had nothing to go off of when he gave me the quote. Long story short, i ended up taking it to him and i couldn't be happier. Your quote is pretty reasonable. You wouldn't believe how much difference that center resonator makes with the exhaust note. I had it straight piped from the resonator back then took it back to him a week later and had him cut that last resonator out and it made a huge difference.
Thanks, that sounds encouraging. I'm definitely looking forward to removing the center resonator. It's just the rear resonators that I'm a bit nervous about the effect of. Of course, they're also on the narrowest section of piping, so it makes sense to eliminate them.
I don't know if the SC300's setup differs and how.
It is my next upgrade. We are recovering from a huge Snow Storm. Only been out to make necessary errands. Shop Quoted me $79 just for simple resonator deletes. But I'm going with the 2.5" Stainless Steel from the cats back, to my Borla's. All resos deleted.
Make a quick exhaust video when you're done, as I will do. My exhaust note now is very sexy, but a quiet rumble at idle. Has a deep note from idle to like 4k Rpms. But ordinary folk may still not realize this foreign car has a potent V8 under the hood. That is why I am going louder. I want it obvious what's under the hood. Plus, nothing like pulling up next to a Mustang or something comparable, with an aggressive Japanese V8 humming. Makes me smile just thinking about it.
Good stuff man.
Good stuff man.
get them all outta there
....weight reduction also! haha
I've never made or posted a video, not sure if I have the means to.
I'm hoping if I bring my scale along, I can get the guy to weigh the stuff before putting it on the car. That way, I can compare it to what was taken off and contribute more weight reduction numbers for others. Axleback mufflers reduced nearly 10 lbs. I'm hoping for that much or more again, but we'll see.
