SC- 1st Gen (1992-2000)
Oversized or wheel well rubbers unite!
Old 12-19-14, 09:48 PM
BlackIRON
BlackIRON's Avatar
Default Oversized or wheel well rubbers unite!
Sooo i have had two Sc's on both i have had oversized wheels that look so beautiful but always seem to rub up on my rear wheel wells and it eats up the tire a noticeable amount. On my first car not so much, but on my new car it seems to rub at almost every chance and god forbid i load up with 3 other people. I am going to replace my shocks but im sure its because the rears poke out of the well a good amount. Does anyone else have any rubbing issues?
Old 12-19-14, 10:01 PM
SC400Zulu
SC400Zulu's Avatar
What setup are you running ?
Old 12-21-14, 04:53 AM
BlackIRON
BlackIRON's Avatar
I have 19's ill show you guys some pics.
Old 12-21-14, 10:46 AM
turbodremz
turbodremz's Avatar
Roll your fenders, get some coilovers, add some camber. Done. That amount of poke isnt bad at all, I used to run a 295/40 on a 17x10.5" rim 20et and I cracked my rear fenders at the apex of the wheel well and added a new line to the tread pattern.
Old 12-22-14, 07:47 AM
estomax
estomax's Avatar
Yeah start by removing that plastic lining in the fender well with a phillips screwdriver, that cured most of my rubbing right away, after that you will want to cut the rear fender lip down to about 1/4 to 3/8 inches and roll it gently as much as you feel you need (so it doesn't dimple)
i am running 245/45r19 in the back, super oversized :P tried to do that in the front too but it's just not possible to turn without destroying the windshield washer tank and side skirt, so right now i got 225/40r19 in the front. i need coilovers badly to fix the lean haha
JDKane527
10-22-10 08:18 PM
scredlex
55
04-08-10 02:18 PM
Ice350
Wheels, Tires & Brakes Forum
05-20-07 04:54 PM
NotFatBoy
07-26-06 10:15 AM
Quick Reply: Oversized or wheel well rubbers unite!
