Stand Alone for 2jzge non vvti
Old 12-16-14, 11:16 AM
newdude1
newdude1's Avatar
Default Stand Alone for 2jzge non vvti
I have been researching for a while now and cant seem to find a straight answer. Im looking at rebuilding a 2jzge motor non vvti( built bottom end, cams, turbo, etc) So I been trying to find a stand alone like AEM but everything seems to be for a vvti motor or the gte motors. What are people using for na-t setups that are non vvti?
The car is a 93 sc300
Old 12-16-14, 11:29 AM
newdude1
newdude1's Avatar
30-6101 Series 2 Plug & Play EMS. TOYOTA: 93-97 Supra Non-Turbo
This is the only one I can find but its for a Supra. Will this work (plug and play) for a SC300?
Old 12-16-14, 09:28 PM
sc3757
sc3757's Avatar
Pretty sure the turbo or non will plug up. Just differnt stuff on them so it can run turbo or non turbo setups on plug in
Old 12-17-14, 03:28 AM
lexforlife
lexforlife's Avatar
Do you plan on running pump or flex fuel.. if pump only or e85only then arm 1101 is pnp with just adding wiring for map and Iat .... if flex fuel then 6101. I may be selling my aem v1 1101 to go to pro efi 112 .. if you are using 1000 to 1100 cc injector and 67 mm turbo then my tune is in the box and ready to run ,just a little tweaking
Old 12-25-14, 08:12 PM
Jermmzz914
Jermmzz914's Avatar
you can use the aem ems standalone from a tt supra. i personally run it on my na-t non vvti setup and it works like a charm. you also have the option to swap for a GTE later on if needed
Old 12-26-14, 12:34 PM
pioww
pioww's Avatar
there used to be decent support through the forums on the AEM website. Now all that good information is gone. I have AEM and I would avoid it, just for that reason. Find a tuner that you plan to use and then ask the tuner what they like to work with.
Old 12-27-14, 05:41 AM
Dexter72
Dexter72's Avatar
Check out Megasquirt 3 DIYAutotune, I think they also make a plug and play setup for the JZ. Check out that site. Costs less than AEM, Plenty of Support online. There is a Megasquirt forum and shared Maps. I have an older Megasquirt 2 im going to run my 2jzge off of.
Old 12-27-14, 07:02 PM
1997Soarer
1997Soarer's Avatar
ProEFI works. You just have to adjust a few settings in the program. My friend has it on his 97 SC
Durangosc
04-03-12 12:35 AM
Not Daniel
IS - 1st Gen (2001-2005)
11-28-11 11:18 AM
jmlex
09-14-06 03:35 PM
raoke
12-26-05 12:09 AM
the_ez_rhino
SC- 1st Gen (1992-2000)
04-23-02 09:18 PM
Quick Reply: Stand Alone for 2jzge non vvti
