SC- 1st Gen (1992-2000)
Squealing when turning left
Old 11-24-14, 08:53 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Default Squealing when turning left
My 92 SC's steering feels like it's brand new, runs straight at 80, don't even need to hold the steering whell, essentially. But a problem has popped up that I've noticed. When I make a slightly hard turn to the left, an on-off squealing occurs, no clunking, just repulsive screaming that comes from the right side. I have yet to remove the wheel and check things out but I did notice a good amount of fluid that seemed to be coming from the strut on the pass right front. I'm pretty sure it's the strut given that the struts are OEM, and the steering/alignment is only a few years old and was recently tuned and turned.
Have anybody else ever had this issue?
Old 11-24-14, 09:55 AM
eknine9
eknine9's Avatar
It sounds like you've already found the answer.
When you turn left, weight shifts right and the strut is low on hydraulic fluid due to the leak so when it compresses it squeals. Replace the strut and then see if the sound continues... or maybe it's time for some coilovers?
Old 11-24-14, 03:50 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I'll be getting the struts replaced here in a few days. I'll post the results.
Coilovers would be cool...but 18 inch rims wont go well go with the drop...
Old 11-24-14, 11:06 PM
eknine9
eknine9's Avatar
I've got 19's and rolled fenders, you might be able to make it work depending on how thick your tires are,
Old 11-25-14, 06:56 AM
oldManTan
oldManTan's Avatar
That's the point of coil overs, they're adjustable. So you can even lift your car instead of drop it with the right coil overs lol. If i wasnt so busy and lazy i would lift my car for the winter, but who has time for that.
Old 11-26-14, 06:08 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
So I bought some Megan LP coilovers. I'll post up the results.
Old 11-27-14, 12:38 AM
eknine9
eknine9's Avatar
Nice choice, I've got the same set on my car, and I've been impressed these past 2 and a half years. It's a lot smoother than any lowered car has a right to be.
Old 12-07-14, 08:58 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Sqealing is non existent, coilovers fixed my issue! Don't they always...?
Old 12-26-14, 03:21 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
So the sqealing disappeared but shortly after the first drive there was a thump-thump-thump...got to my destination and poked around a bit to find I didn't tighten the lug nuts back on! I have removed the wheels so many times I forgot to tighten them up the last time around! To make things even more interesting, I went over 80 MPH...that would have been a totaled SC if those wheels came off!!!
Got that taken care of, then a minor noise generated after the first few days. Every time I would turn the wheel, there was a "clunk". Sure enough, rack and pinion bushing is non-existent. Well, time for some daizen rack bushings!
ATLs460
RX - 1st Gen (1999-2003)
23
10-04-16 10:21 AM
penone
Suspension and Brakes
10-07-15 05:24 PM
RXGS
07-06-14 10:10 AM
DK Audio
19
04-14-04 09:16 PM
Quick Reply: Squealing when turning left
