Rear Turbo Build SC400
#46
I know that you're really set on having a rear mount, but what if you did a low mount like in the pictures? You'd be surprised where a subaru td04 can fit (plus they're super cheap). Plus, for the budget you built out you could do it pretty easy (it's been done on a lexus before). I'll make a price list real quick.
turbos: 150-200 a piece (450 for ported and rebuilt ones)
piping for the exhaust: 100 (that's including the flanges needed to plumb in the downpipe
intercooler set up: 750 (that's with custom fabricated piping)
bov: 150
oiling set up: 150 (that's on the high side.
and lets say 250 for miscellaneous parts to add in later
With all of that you're still under 2 grand. with that you could use the rest for engine management tools.
bov: 150
You can probably use oil-less turbos but you will be spending much more money per turbo. Plus with the much smaller turbos, they have internal waste gates set at around 7-10 psi leaving you less likely to turn up the boost and blow up your engine. Most people I know that use these turbos are people who want a little more power with out the heavy modification and engine build
#47
that would be the best bet, right by the tranny where the cats used to be. there's plenty of room there i think and you wouldn't need an oil pump for the turbos then.
#50
You have to have cats here in NC, that was the other reason initially for the rear mount concept. But if I waitt until my car is 25 years old then it won't matter because it will fall into a different emissions category. But I want my power now
#52
What kinda turbos are you thinking about using? Do you wanna do a single or a twin setup?
#57
I'm gonna go with either the wrx td04's or t3's. Small and fast spool to get power lower in the spectrum, will probably clock around 8 psi max. Still researching but I'm hoping running the turbos at the primary cats will eliminate the need for a dedicated oil system? I'm not sure of any issues I may run into by tapping into the engine though.
#58
#59
I like that setup of putting the turbos right behind the engine by the transmission....you could fit two small turbos back there........only problem is you need to have some fabrication skills....welding etc to be able to pull off a kit like that for under 4k...
Wonder if you could use stock twins from GTE and seperate the two turbos and run them on each side...since they came be found for cheap
I would definately rock a setup like that with a 5spd swap....would be alot of fun
I am surprised that there isn more twin turbo kits done on V8's.....all that exhaust pressure if perfect for spooling up turbos.....but most muscle cars are supercharged
Here is a setup on ls400:
#60
I would say whatever turbo you get, make sure it's a journal bearing (subaru td04 comes to mind) they respond better to over pressuring the oil. I know that there's a kit for the oil feed for the 1uz,. As far as the drain, just tap the oil pan above the oil pickup. That should be a good oiling setup. As far as using gte turbos, I would think you'd run into issues controlling boost and fabricating brackets for them.
