SC- 1st Gen (1992-2000)
So just did my coilover install and air bag light on
Old 08-23-14, 08:29 PM
speedstarr
speedstarr's Avatar
Default So just did my coilover install and air bag light on
The first thing tha'ts strange is now my airbag light doesnt turn on. I did accidentally un clip the yellow wire looms but I re attached both sides. Did i forget something?
Old 08-23-14, 08:51 PM
MongooseGA
MongooseGA's Avatar
You detached an airbag wire? Was the battery still connected? If so, that would likely be your problem.
Old 08-24-14, 04:00 PM
Snx37
Snx37's Avatar
You probably detached the one under the front fender
Old 08-24-14, 07:02 PM
Joey-E
Joey-E's Avatar
Since you lowered it check your harness.
Old 08-25-14, 07:21 AM
Vrank
Vrank's Avatar
have to reset itthrough the diagnostic port since you disconnected it. Do a little searching on supra or sc airbag light reset, what I did was get two male pins and some long wire, pinned them into the proper spots in the diagnostic port, put the seat all the way back and used the bolts for the seat on each side as my ground points while sitting in the seat. You'l have to ground the two wores in a metronome type fashion and watch the airbag light flicker weird, sometimes it takes a minute, sometimes its real easy and quick. I've done this a few times, but it's been a few years
Old 08-25-14, 07:44 AM
Studiogeek
Studiogeek's Avatar
You might want to pull the code first to verify that you didn't create a real issue that set the warning off.
Some people use a simple Radio Shack 3 position toggle switch to make it easier going from pin to pin to ground when re-setting light as Vrank outlined above. Totally not necessary, but helps if you don't have metronomic timing.
Everything you need is here: http://lextech.org/forums/index.php?...0f26&topic=9.0
Old 08-26-14, 01:45 AM
speedstarr
speedstarr's Avatar
Great info thanks guys!
GadgetRick
GX - 1st Gen (2004-2009)
13
08-26-17 09:51 PM
Hattrix
01-01-15 11:22 PM
ZLooney300
Performance & Maintenance
06-05-11 10:10 AM
rg_gibson
08-16-09 08:38 AM
Quick Reply: So just did my coilover install and air bag light on
