SC- 1st Gen (1992-2000)
sc300 head gasket
Old 08-07-14, 01:31 PM
chillchewy
chillchewy's Avatar
Default sc300 head gasket
Ive been searching all day for a detailed repair manual to change a head gasket. I really dont want to pay for the repair manual. Does anybody have the repair manual to change a head gasket?
Old 08-07-14, 01:44 PM
Ali SC3
Ali SC3's Avatar
search for 95 supra repair manual, its floating around somewhere. you want the engine section for 2JZ-GE and its the same as a sc300 is.
Old 08-07-14, 01:55 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
http://www.mk3supra.org/topic/43-gui...a-head-gasket/
Supra headgasket change
Old 08-07-14, 02:07 PM
Kris9884
Kris9884's Avatar
If I can make any suggestions it would be to buy a box of ziplock bags with the zippers ( just easier when wearing gloves ) and label all the bolts and braces, brackets, plugs etc that you take off. This will help for reassembly time and you wont have spare parts. In a nutshell, its fairly straight forward..
Old 08-07-14, 02:27 PM
chillchewy
chillchewy's Avatar
Ive changed head gaskets on 4 bangers all day like celicas and hondas and all that this is my first with the 2jz I just dont want to mess somethin up
Old 08-08-14, 09:48 AM
Ali SC3
Ali SC3's Avatar
its like a bigger much nicer pointing the correct way celica motor. you should be fine. just note the torque sequence for removing installing the cams and heabolts. if you do not follow that you either warp the cams cause they are so long and just waiting to warp, or you bend the head cause its aluminum. It's pretty rare that someone does that but if you do not follow the procedure at all it can happen.
Old 08-08-14, 10:36 AM
chillchewy
chillchewy's Avatar
Should I use felpro or eristic head gasket. Has anybody heard of eristic brands are they any good
Old 08-08-14, 12:07 PM
Tabaka
Tabaka's Avatar
Either should be fine, I know that eristic is cheaper. If you are truly concerned, you can't go wrong with OEM Toyota. I have a brand new Eristic one if you're interested. PM me for a cheap price.
Old 08-08-14, 12:35 PM
Ali SC3
Ali SC3's Avatar
did you know you started a whole new thread with the exact same title, you could have just asked this in your other thread. can you give the forum rules a read please. your threads have been merged.
Old 08-08-14, 06:01 PM
chillchewy
chillchewy's Avatar
Yeah im sorry I should have asked here. I was in a hurry and I did not think. my deepest apologies. Btw I just went and got an oem head gasket. Anybody have arp studs laying around and trying to sell them? Im looking for a good deal
Old 08-08-14, 06:06 PM
mikef
mikef's Avatar
you should replace the valve gaskets while your at it, 74 in lbs
Old 08-08-14, 06:10 PM
chillchewy
chillchewy's Avatar
Yeah I plan on changing all the gaskets and water pump and radiator. I dont want to put the engine back together and have a leak somewhere and what not
David_K
Performance & Maintenance
27
11-17-15 12:18 PM
jwynn
06-02-15 09:41 AM
jwynn
06-01-15 08:57 PM
AlexAgyago
19
08-02-10 04:45 PM
Quick Reply: sc300 head gasket
