SC- 1st Gen (1992-2000)
SC300 SC400 Dashboard Differences?
Old 07-28-14, 03:38 PM
mikevandam
mikevandam's Avatar
Default SC300 SC400 Dashboard Differences?
I recently bought a black dashboard and I have a tan one in my SC currently. My question, after attempting to search for the answer, is there a difference between dashboards? Its pre 97 if that helps and correct me if I'm wrong but if the chassis code has a '30' then it doesn't have a passenger airbag whereas the '31' does? This might sound dumb but please clear up the air for me and potentially others in the future.
Old 07-28-14, 07:18 PM
BeaksSC
BeaksSC's Avatar
Um not sure if this solves your question but I guess one has slot for passenger airbag and one doesn't
Edit
Mine is a 95 and mine has the airbag if that clears up anything, based on what I'm finding, the 92 doesn't have the airbag? Idk about the other years
Old 07-28-14, 08:08 PM
MongooseGA
MongooseGA's Avatar
Early cars had no passenger airbag. I don't remember what year they started putting them in.
Old 07-28-14, 08:10 PM
97-SC300
97-SC300's Avatar
92 was the only year that didn't have airbags on the passenger side.
Old 07-29-14, 05:21 AM
99rx
99rx's Avatar
92 had no airbag on the passenger side.
93-~96 had the airbag/woodgrain combo
97-00 If I recall, had a solo airbag in the dash, the woodgrain was a separate entity.
Old 07-29-14, 06:30 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I've swapped the dashes between 92 and up to 96 and they do swap, but the brackets are different behind the airbag and you have to do some finagling to make it fit on the hangers on that side coming out of the dash.
As said 92 was the only year without the bag.
Old 07-29-14, 09:11 AM
mikevandam
mikevandam's Avatar
Ok that tells me alot actually. Is there any distinct observations that the dash came from a 92 with no airbags? Like a side by side comparison of the two? because it did not come with the dash airbag. The reason I ask is to for-warn my self just in case I can't line up the airbag or something in that nature.
Old 07-29-14, 02:56 PM
Kris9884
Kris9884's Avatar
Uh... Unless I'm misunderstanding your question, the super obvious void where the airbag would be should be a dead giveaway.
Old 07-30-14, 05:29 AM
99rx
99rx's Avatar
On the 92, there is NO spot for a passenger airbag. All other years have some sort of cutout in the dash on the passenger side for it to slide it.
chrissc
12
05-10-13 08:44 PM
ES330MD05
06-25-12 04:31 PM
saurah
07-23-10 05:34 AM
lexforlife
SC400 / 300 Classifieds
02-11-08 10:09 AM
SPORTcoupe
06-14-05 04:17 PM
Quick Reply: SC300 SC400 Dashboard Differences?
