SC- 1st Gen (1992-2000)
Intermittent Unlocking of Doors
Old 06-18-14, 09:51 AM
OG Dada
OG Dada's Avatar
Default Intermittent Unlocking of Doors
My 1995 SC400 is still giving me problems and I'm getting tired of it, seriously. I was planning on selling it quick after getting the 5 speed, but want to fix the problems I'm having with it first to get top dollar since its a high mileage. What's happening is it keeps on unlocking itself without any warning or any reason at all without pressing the unlock button on the switch or the key FOB, and it happens even when I'm driving. And the lock button on either the switch or the key FOB will no longer work after all this happens, so I need to manually press the locks, until it happens again after a while. What''s really pissing me off is there are times that when I walk up to the car the next morning it's already unlocked.
Here are things I've already done before the problem occurred. About 2 years ago, my window stopped working while I was driving. It was just stuck in the open position and I couldn't close it without helping the motor push it up. So, to try and fix it, someone suggested replacing the ground wire, it's the color white with a black stripe on it, and a little bit thicker than the other wires. I replaced the wire from the plug of the switch, then tapped it in to a good ground on the door, which someone also suggested worked for him and so I did. It did not fix the window problem though, later on it turned out to be just the window motor needing to be cleaned due to carbon build up inside the motor. The locks and alarm worked fine for the past 2 years like that, with only one side effect. Whenever I would shut the door it would unlock twice. Didn't bother me much since it didn't make any difference to the functionalities of the alarm nor the locks.
I only had the key without the button when I got my SC, so I had to manually open the locks every time back then. I grew tired of it and eventually bought a brand new key FOB from Lexus Sewell. I got it programmed to the car with the instructions I found here in CL, and it worked perfectly fine for about a year or so. Then this problem started. Last night I replaced the ground wire again, but this time I put it back the way it is supposed to be. I rewired from the switch to the fuse box in the foot panel. It still does the same thing. Unlocks itself with no warning, but not as much as before, where sometimes it almost wouldn't stop. But I noticed that the lock function only works when the key is in the ignition. When it's out, it doesn't work at all. I tried using the switch from my other SC, which works perfectly fine, and still the same, so I know its not the switch. Anybody help?
Old 06-18-14, 06:18 PM
TheAzn
TheAzn's Avatar
Could be the Door Lock Control/ Theft Deterent ECU.
I've been having my factory alarm sounding for no reason. I had my dashcam run one time when I locked and left the car. Caught on camera It sounded like my car re-locked itself and triggered the alarm on its own...
Old 06-18-14, 10:55 PM
t2d2
t2d2's Avatar
Have you tried taking the battery out of the FOB to see if it's sending an errant signal? Probably not the case, if it's unlocking itself overnight, but it would eliminate one of the easiest things to check.
Old 06-19-14, 06:27 AM
soarer93
soarer93's Avatar
I suggest - opening the door(s) and noticing the exposed wiring where the rubber boot should be protecting it from water -
Usually happened to my car after pressure washing it - ensuring water got in there, or after a long heavy rain - that being said.. I just ended up pushing the boot more intowards the door to better cover the wires - and havnt had that issue since.. Though best option is to replace that boot, or silicone it up or something..
though mine would actually LOCK instead of Unlock.
Old 06-19-14, 09:23 AM
OG Dada
OG Dada's Avatar
Hmmm... So yours locks instead of unlocking... I read somewhere here in the past that our electrical have a common ground for each electronic part. I don't know if I messed it up when I grounded it on the door that's why it immediately had that effect where it unlocks twice everytime I shut the door. It's just weird that it developed that intermittent unlocking in time and not immediately like the fore mentioned.
Old 06-19-14, 10:32 AM
soarer93
soarer93's Avatar
Im still betting its moisture in the wiring -
Old 06-19-14, 10:48 AM
OG Dada
OG Dada's Avatar
It got me really thinking, cause one thing I noticed ever since this problem started, is it only happens when the weather is cold. When it's really hot it never malfunctions like that. I'll open it up and take a look. I know for sure that there's a rip in the rubber loom. I did read somewhere here that there are wires that do get cut from there so I'll take a look. Thanks for the input. I'll report back whatever happens.
Old 07-18-14, 11:10 AM
OG Dada
OG Dada's Avatar
ISSUE FIXED!!!
Old 07-18-14, 01:28 PM
Kris9884
Kris9884's Avatar
Originally Posted by KingPhilip
Was is the wire/looming in the door?
Old 07-18-14, 02:31 PM
OG Dada
OG Dada's Avatar
Nope. It's in the wiring harness leading to the o2 sensor. Click on it to see the pics I from the other thread.
Old 07-18-14, 03:02 PM
Kris9884
Kris9884's Avatar
Oh lol, the blue text color made it look like it was just bold, didn't even think to click on it. Awesome fix, I would never have thought to go under the car for this issue... Crazy..
Old 07-18-14, 03:07 PM
t2d2
t2d2's Avatar
Those were some gnarly looking wires! I've found two partially bare wires in my engine bay, worn out from where they bend toward the connector, but nothing nearly as bad as your's. And mine were only one bare wire per connector, so not a bunch of adjacent bare wires touching each other.
Old 07-18-14, 05:48 PM
94sctt
94sctt's Avatar
I clicked on the ISSUE FIXED but didn't see the pictures.
Old 07-18-14, 05:51 PM
94sctt
94sctt's Avatar
Never mind. Didn't think to check the other pages on the thread.
Old 07-18-14, 05:58 PM
OG Dada
OG Dada's Avatar
I wouldn't have guessed it in a million years. But I guess this is where "the central grounding for each electronic part takes place" if that affected the alarm as well.
Yeah, the previous owner had a really bad oil leak going on before I got the SC. I fixed it, then a couple years later another oil leak came out. I've seen a lot of wire insulations frayed just like this due to years of being soaked in oil then the engine constantly heating it up. The insulation becomes really brittle and just chips off when rubbing against each other.
iltolesjr
01-03-19 04:00 PM
NyCrAzY
RX - 1st Gen (1999-2003)
01-14-12 06:04 PM
Rider
ES - 5th Gen (2007-2012)
04-24-10 08:05 AM
Blunderoos
12-01-08 05:52 AM
airahcaz
09-12-05 05:55 PM
Quick Reply: Intermittent Unlocking of Doors
