Skyline Injectors Work on 1JZ?
I've done some research and I could only find one thread in the forum that talked about using RX7 injectors in a 1JZ. The article stated that the injectors were too short and needed adapters but nothing on RB injectors. I'm specifically talking about the RB25 side feed high impedance injectors but maybe we can have a list of all compatible injectors as a sticky?
Here are the specs of the injectors that I'm referring to:
Flow Rate in CC per minute: 720CC/min @ 43.5 PSI or 3 BAR
Resistance: 12.6 ohms
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30PSIG/ Max 100PSIG
O-rings Included: YES
Warranty: 1 Year Warranty!
Amperage: 1.0 Amps
BigGreen
SC400 / 300 Classifieds
05-08-09 09:49 AM
