2jzgte with W58 speedo or odometer not working....
Hey guys I am unable to get my speedo to work....I am using W58...It was working prior to doing the swap....
I have it wired up correctly per wiring diagrams:
Pin 1 of Speed Sensor to pin 10 of IJ1
Pin 2 of Speed Sensor to pin 6 of IK1
Pin 3 of Speed Sensor to pin 7 of IK1
Also my odometer is not increasing eihter....it is staying the same amount of miles...
Any input guys would help out a lot....
From my thread when I had the same problem. May help
I used the transmission speed sensor(right rear of the transmission) to get the speed signal to the gauge cluster. That is how the wiring diagrams show it, the three wires on the NO.1 speed sensor are Yellow( pin 1), Red(pin 2) and Blue/Red(pin 3) of the speed sensor connector. The speedometer signal goes from plug 90980-10921 to the large middle plug (C14) on the cluster with 23 pins.
I spliced the orange plug under the passenger carpet and ran it to the speedometer. I don't know why the signal wasn't getting from there to the cluster, but I just hard wired to be through with it.
Speed sensor diagram for 1JZ, probably roughly the same for sc3,sc4, supra etc.
Pic of the orange body harness plug. Pin 7 is to the speedometer, once again it's blue/red.
Pic of the gauge cluster plug (c14), pin 13 is the speedometer signal once again it's blue/red. This is the big middle plug on the cluster.
*Cliff notes* splice the blue/red wire off the speed sensor to the back of the cluster.
