Running new wire through original door loom???
What's the best method of getting new wire through the door loom? I'm on the verge of drilling new holes which I really don't want to do as I want to keep the car looking as stock as possible.
I just can't seem to push/pull new wire through this damn rubber. It's so tight, I have two sets of 16 Gauge wiring I need to get through on each door. I know not to use WD40 as it will chew through the rubber over time, I do have a can of Toyota's White Grease Spray...not sure if that will eat the rubber though. Any other methods? I've disconnected the wiring harness to give me more play but still struggling. My fingers have taken a sufficient beating already. I've tried the coat hanger method as well...
Advice please! I have much to do, and this is holding me back.
When I ran my speaker wires, I wanted to stay stock looking too and what I had to do was cut a tiny little slit about half way in the rubber boot and do it in stages. I used the coat hanger but I took the tip and rolled it over with some needlenose pliers so it wouldn't be sharp and that gives you a little more ability to just push and plow through without fear of ripping anything. Once I got it to the slit, I pulled it through and then started over for the second half. when I was done, I wrapped it back up in electrical tape. Been fine for last 5 years or so.
I tried and tried and tried and couldn't do it. It's a bit colder today then the last few days and my hands were painfully numb from the cold. Spent over a hour and a half on this issue, and couldn't get one so definitely won't fit two. My driver door grommet was cut on the bottom anyway and exposed so I I just wired into that hole, and above the original grommet where they fit snug. A little ghetto which I was trying to avoid, but I fought with it for too long. If it warms up more tomorrow I'll try one last time, my wiring isn't finalized yet just sitting in place. I might silicone seal it or pick up a door loom kit.
Quick question....does anyone know the point of these two rear deck covers that easily pop in/out? They sit between the sub and rear deck speakers...but why? I was thinking of mounting my crossovers to the undersides of them for a nice symmetrical look.
