SC- 1st Gen (1992-2000)
New SC owner need to work out some bugs
Old 12-16-13, 07:28 PM
Bdub215
Bdub215's Avatar
Default New SC owner need to work out some bugs
I just picked up a 92 SC300 5 speed with 104K on the clock. One owner car. So far i've noticed the Power Mirrors arent working, The Power Trunk realease isnt working, Memory seating also isnt working. The Key way to lock the trunk inside the car appears to be stuck but im not 100% sure. TB/WP dont appear to have been done but other then that is car is pretty clean. I can handle the mechanical bits. This is (personally) my first SC, My family's Second (still have the other) and our 4th lexus product.
I Just need some advice on the Electrical bits and i'll be posting in this section alot more now lol. Already trying to figure how to fix a Code 71 on my Dad's SC.
couple photos..
Old 12-16-13, 07:46 PM
mikef
mikef's Avatar
this car has a ECU for almost everything, and its a good thing, find your mirror ecu and open it up or replace it
the other problems, you just have to start open things up with a multimeter in hand
Old 12-16-13, 07:54 PM
iridebmx
iridebmx's Avatar
doesn't sound like a ecu problem. more like a fuse is blown problem
Old 12-16-13, 08:11 PM
Bdub215
Bdub215's Avatar
Checked every fuse on the mirror circut (Radio No2 and ECU-B because thats what i thought) I will check them again. i dont really mind the memory seats so much but i need the mirrors to work for PA inspection when that time comes.
EDIT: Fuses Check out.
Old 12-16-13, 09:19 PM
eknine9
eknine9's Avatar
Are your trunk lift supports still working?
When they go out the interior trunk release button will have trouble popping your trunk open, but you should still be able to open the trunk with the key from outside the car. I'd check and replace that first before trying to chase down any electrical or mechanical gremlins. If the trunk lift supports are operational then I guess you'd start chasing down the problem elsewhere, but figured I'd offer a possible simple solution thats easy to check before u start looking.
Old 12-16-13, 09:21 PM
scENFORCER
scENFORCER's Avatar
I was going to say fuses too. Did you check the fuse box hidden under the kick panel too?
Old 12-17-13, 03:12 AM
Bdub215
Bdub215's Avatar
Lift supports are ok. I did check the inside kick panel.
Old 12-17-13, 04:38 AM
Biddles
Biddles's Avatar
When I got my car someone redid the speakers in the door and forgot to connect the memory seating wiring back in, check that by removing the door panel. The mirror ecu can be a pain in the *** though...
Old 12-17-13, 08:49 AM
Slaker13
Slaker13's Avatar
For the power trunk release is the the valet button pushed in or out? the silver circle with key hole between the gas switch and trunk on the lower left side of steering wheel, mine was pushed in and kept my power trunk switch from working.
Old 12-17-13, 10:08 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
As to the power trunk release, the valet is probably locked. If you dont obtain the key, open it up, remove a metal cylinder covering the lock assembly, and press the black button and walla its unlocked. For this DIY search "replacement nubs for center armrest Lexus" and it will pop up gl
Old 12-17-13, 01:40 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I think the mirror issue is the ECU, which is a pain to get too, if all the fuses are good. I do know the clock and the mirror are tied together, along with the door locks, if I am not mistaking. See if the door locks and clock works, if so, then check that darn mirror ecu. Now that I am thinking about it, I think the trunk release is also tied in to the same circuit. Check the fuses in the engine bay. I believe it is a 10 amp fuse.
Old 12-17-13, 01:45 PM
Bdub215
Bdub215's Avatar
Its looks like its stuck half way in. None of my keys make it move an inch.
I've got two master keys (with the button) and one spare (without the button) and none make that lock cylinder do anything. I'm gonna go look at that thread and see what i can do.
Locks work fine, Clock works fine. i'm gonna disassemble the lower dash and report back on what happens.
Old 12-17-13, 03:23 PM
Bdub215
Bdub215's Avatar
Power trunk works! Lock is frozen or broken. It doesn't turn. Now the mirrors ...
jonas's RX
01-20-21 09:40 PM
VINCE9164
24
09-26-11 02:07 AM
STRTORPTR
11-03-10 08:21 PM
nfordhk
09-03-10 04:28 PM
Quick Reply: New SC owner need to work out some bugs
