SC- 1st Gen (1992-2000)
dis-connecting the battery
Old 11-28-13, 10:43 AM
LorenzoE
LorenzoE's Avatar
Default dis-connecting the battery
Would dis-conecting the battery on a 1995 sc400 mess anything up???
Old 11-28-13, 10:50 AM
INTIMAZY
INTIMAZY's Avatar
9 out of 10 dentists agree that nothing will happen.
Old 11-28-13, 10:54 AM
LorenzoE
LorenzoE's Avatar
ok, i've been reading and people have problems that there car wont start after reconnecting it.
Old 11-28-13, 11:22 AM
INTIMAZY
INTIMAZY's Avatar
It will reset your tune. Which the ECU will relearn anyway. This is normal. There is nothing unhealthy for the car about it.
Everything is going to be alright.
Old 12-01-13, 06:26 AM
xshurikx
xshurikx's Avatar
YES, you will need to RESET your CLOCK, thats about it lol.
dont worry. but since you will need to have the ecu relearn you can teach it new tricks now. either power or gas saver or in between. there was a thread about this somewhere.
Old 12-01-13, 07:36 PM
Dawa
Dawa's Avatar
lolz
anyways, remember the correct procedure for disconnecting the battery is to remove negative first, and then positive. and installation/hook up is postive first, then negative. just trying to help, i see a lot of people do this wrong ><
Old 12-02-13, 04:04 PM
Candela
Candela's Avatar
Originally Posted by ProperD
lolz
Never really thought about that. Now I'm not sure in what order I do this
OP no problems just gonna have to reprogram your radio station presets
Old 12-02-13, 04:40 PM
scENFORCER
scENFORCER's Avatar
Newb's gotta start somewhere. Nothing wrong with an honest question
Old 12-03-13, 09:18 AM
Shrugy
Shrugy's Avatar
Nothing wrong except that I experience problems with my car not idiling properly.
I have to have my foot on the gas but this is only until i shut it off, I guess it just has to learn its idle RPM.
Once you turn the car off you'll be allright.
I highly reccomend you drive the car when you disconnect it though to insure its okay.
Old 12-03-13, 12:29 PM
Ali SC3
Ali SC3's Avatar
sometimes if a sensor has gone bad or out of range, the ecu will keep going on like normal because it has already learned some stuff. Then, when you reset it and it tries to relearn it may not learn correctly, and that means there is some type of underlying issues going on and hopefully you will throw a check engine light for it.
majority of the time resetting the ecu does not do anything bad, but you are reforcing the ecu to learn stuff like idle position, so if it can't learn it this time around for some reason its not going to "get it right" at first.
the solution is to keep resetting, try the morning before the first start and drive it till its warmed up. if still having issues then probably something needs to be fixed/replaced.
jaywish
10-06-13 06:49 PM
deputy865
Performance & Maintenance
05-16-13 06:31 AM
1WILLY1
07-26-10 10:34 PM
viruzniper
05-02-09 01:50 PM
breds16
01-15-09 06:45 AM
Quick Reply: dis-connecting the battery
