SC- 1st Gen (1992-2000)
Absolute bare minimum wiring required for 1jz sc300 question! help
Old 11-15-13, 08:21 PM
ppayne1201
ppayne1201's Avatar
Default Absolute bare minimum wiring required for 1jz sc300 question! help
alright so ive got a build thread going already . ive got a 92 sc300 with a 1jz swap. it was running driving etc. i swapped it all. but then decided to make it into a full out track car, stripping pretty much everything out of the car. not sure how many other people out there have stripped theres all the way down but what is actually needed? id prefer to remove alll of the chassis harness etc since the engine harness has the ignitor/ecu/ on it etc. but could i run a painless performance fuse block and go from there?
no need for the ignition etc, ill have it running off of a push button start etc just to simplify it some more
sorry i sound retarded right now on this but wiring isnt my thing. haha any help on this would be great
https://www.clublexus.com/forums/bui...k-project.html
Old 11-17-13, 11:22 AM
ppayne1201
ppayne1201's Avatar
Nothing at all?
Old 11-17-13, 02:35 PM
Vrank
Vrank's Avatar
Switched power to injectors/ignition, then switched power to pins + b/igsw at ecu.
Give pin batt constant 12v, keep all grounds as normal. Super simple.
Have fun.
Poopra98
Performance & Maintenance
10-01-15 02:49 PM
B.Diddy
06-12-12 07:51 AM
mo_jo
03-08-07 07:52 PM
Kaiser
14
06-29-05 11:26 AM
Quick Reply: Absolute bare minimum wiring required for 1jz sc300 question! help
