scrap the 1jz for another or rebuild it
Ok i need some guidance on what to do with my current 1jz in my car, it runs BUT there is a small coolant leak from either a pipe or hose behind the head that i cant see also the car has crankwalk and the twins are dead so my question is should i pull it out and try to salvage it or just buy another 1j? And i know if i bought another 1jz it could have the same problem just want to know what everyone else would do. Thanks
gte & na-t
Crankwalk?
Just get another engine.
Crankwalked comes from HD pressure plate slapping the crank at higher rpm, etc...
Automagic cars it happens from the tight converter.
Get another engine pull the oil pan if the trust washers are in place not sitting in the oil pan you are good to go.
replace the oil pan and you are good to go.
Yeah 1.5 is possible if you going single , it will no work on the ge block if you gonna use the stock twins.
gte & na-t
get a complete 1jz swap or get a gte block., hg, arp studs, oil pump etc..
I drilled and tapped out the upper oil pan for the drain. It still running strong till this day except that the twins are smoking ,
I was a little concerned about that but I took my chances and I thankfully never encountered any oil pressure issues.
OP, I would source some good twins and a GE block. This will be the least cost effective way to go plus you get a little more displacement. That stock twins on that GE block are a lot of fun.
I guess it all depends on what your budget and future plans are.
If you just want the car to run for now, maybe just find a 2jzge block in good shape. Which you can always turbo later if you're looking for more power.
Also, Stock twins are relatively inexpensive, but for that matter, the whole 1jz motor isn't too bad. If you're doing all your work than or concerned about labor costs, it just boils down to how much you want to spend on parts.
Hopefully there isn't anything else wrong with your motor, but If you're not in a rush and have other means of transportation, acquiring another gte motor wouldn't be a bad last resort.
