SC- 1st Gen (1992-2000)
Replace Grill
Old 08-30-13, 04:27 PM
3dog
3dog's Avatar
Question Replace Grill
I've got a 99 SC400 and the grill is cracked.
No big deal I thought so ordered a new one.
I had the car at a body shop to get a quote on some
touch up on the paint and asked if they could put the grill on
for cheap so that I woiuld not have to mess with it.
I thought it was easy.
They tell me you have to take the whole bumper off.
The estimate is for 2.8 hrs of work.
This seems crazy.
Isn't it more simple than that?
Thanks
3dog
Old 08-30-13, 04:59 PM
k7q
k7q's Avatar
Maybe 1 hour. 1.5 tops to remove and install the new grill. Faster if you don't have the fender liner and the engine plastic tray on bottom.
Old 08-30-13, 06:00 PM
3dog
3dog's Avatar
So you really do have to take the bumper off?
Old 08-30-13, 07:09 PM
MajorSloMo
MajorSloMo's Avatar
3dog, there really is no other way around it
Old 08-30-13, 07:40 PM
93Gotjuice
93Gotjuice's Avatar
Yea but it doesnt take 1.5 hrs to take off and install and put back on.. more like 30 mins lol
Old 08-30-13, 08:33 PM
k7q
k7q's Avatar
lots of nuts, bolts, and screws on the bumper. MAYBE you can remove the grill from the engine bay. just need a small phillips screw driver. grill is held on by 3 screws. also remove the long plastic cover so you can get to the grill.
Old 08-30-13, 08:36 PM
mak89
mak89's Avatar
This works for me, but I have a shine bumper... Takes 1-2 min, remove tray in front of radiator and should have enough clearance. Not sure if same with oem bumper
Old 08-30-13, 08:42 PM
k7q
k7q's Avatar
yea i just check my fertex bumper and i have clearance also. oem should have the same amount of clearance.
Old 08-30-13, 09:22 PM
ASTERiSK
ASTERiSK's Avatar
Bumper doesn't take a long time to take off, you could definitely do it yourself. It's just bolts and screws.
Old 08-30-13, 09:42 PM
sunami02
sunami02's Avatar
D i y .....
Old 08-31-13, 02:11 PM
3dog
3dog's Avatar
Question grill
I was looking at this from the inside.
It looks like it is just 3 screws holding it in.
I'm not good at mechanical stuff but it sure looks
to me like it can be done without taking the bumper off.
Am I missing something?
Why does the bumper have to come off?
Thanks
3dog
Old 08-31-13, 03:29 PM
187's Avatar
I took mine out without removing the bumper, what is this?
Old 08-31-13, 05:46 PM
Tabaka
Tabaka's Avatar
should be able to remove the top five or so screws on the top and pull the front of the bumper forward to access the grill screws. Just be careful and you shouldn't have to remove the entire thing. However, it is a little bit of a pain to remove the entire bumper. Took me about 2+ hours the first time I did it.
Old 08-31-13, 06:40 PM
mak89
mak89's Avatar
Also if you have the OEM bumper be careful not to stress the bumper piece/edges around the headlights. If you do you can easily crack the clear coat and have a cracked egg shell look.
nysupraman
IS F (2008-2014)
36
02-12-17 08:40 PM
ThumperPup
ES - 5th Gen (2007-2012)
04-18-16 08:29 PM
nhlexus
05-27-11 04:29 AM
OutkastGS3
02-20-09 09:50 AM
Styx
IS - 1st Gen (2001-2005)
07-17-04 11:35 AM
Quick Reply: Replace Grill
