Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300
Sign in using an external account
Register Forgot Password?
Odometer not working
Thread Tools Search this Thread Display Modes
Old 08-26-13, 08:07 AM   #1
crenfro
Trader Score: (0)
crenfro's Avatar
Default Odometer not working
I bought my 92 400 with 146k miles on it and have had it for about a year now. I've knowingly put on about 2k miles and just recently the odometer went out. It's completely blank, no numbers or anything.
Is this a bulb problem? I don't know if it is because all the bulbs are working in my cluster besides my needles. Is is possibly a fuse? What else could it be?
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
92 SC400 - Stock - Totaled 2013
95 SC300 - 1jz vvti, W58 - Current, Build in Progress
crenfro is offline   Reply With Quote
Old 08-26-13, 08:37 AM   #2
SC400slide
In Recovery Mode
Trader Score: (7)
SC400slide's Avatar
Jonathan Hoppman SC400slide
Does the speedometer still work? If so, it's your VSS.
__________________
1992 Lexus SC400 1995 Lexus SC400 1999 Lexus GS300 03 Suburban, 01 Sequoia, 99 Miata, 00 Miata 6 spd
Lebo Boh tak miloval svet...
TLN #49 BURNT BROWNIE
SC400slide is offline   Reply With Quote
Old 08-26-13, 08:54 AM   #3
crenfro
Trader Score: (0)
crenfro's Avatar
Quote:
Yes. Everything in my dash works. And sorry but what is a VSS?
__________________
Old 08-26-13, 09:02 AM   #4
SC400slide
In Recovery Mode
Trader Score: (7)
SC400slide's Avatar
Quote:
Vehicle Speed sensor. I'd first poke around the obvious smaller things, like fuses. Though, the SC needles go out so often.
I'm sure that if the VSS was out, the speedo wouldn't work, and niether would the odometer. It would read "0".
__________________
Old 08-26-13, 10:44 AM   #5
1JZPWRD
1JZ Single SC400
Trader Score: (59)
1JZPWRD's Avatar
I agree with that being the problem. If it isn't, I say it's the cluster itself.
__________________
1992 SC400, Sleeper..522RWHP - 93 octane, 1JZ, BW S366, Soarer R154, ACT Stage 4, 800cc, DM LW Flywheel, MINZ FPR, 3" Exhaust, HKS CF Slip on, HKS BOV, Tial 44 WG, BC 264 Cams, AEM gauges, AEM V2, MKIV Auto LSD!
Follow my build thread.....http://www.clublexus.com/forums/buil...and-links.html
Jay's Interior....http://www.clublexus.com/forums/sc-4...y-1jzpwrd.html
1JZPWRD is offline   Reply With Quote
Old 08-26-13, 11:10 AM   #6
crenfro
Trader Score: (0)
crenfro's Avatar
Ok yeah that's weird then because it doesn't read 0 it's just completely black and not lit up at all. I'll check fuses later after school and see if that's a problem. Could it be as simple as a bulb? Does the odo have its own?
__________________
Old 08-26-13, 05:30 PM   #7
O. L. T.
Keeper of the light
Trader Score: (15)
O. L. T.'s Avatar
Sorry, you need another ODO assembly. Once the gas and heat grid burns out it's done. I have a spare in the attic.
__________________
Mercedes C Class | 19" Staggered Zenetti's | HID's
OESpectrum Suspension | K&N filters | 2" drop
O. L. T. is offline   Reply With Quote
Old 08-26-13, 06:24 PM   #8
1JZPWRD
1JZ Single SC400
Trader Score: (59)
1JZPWRD's Avatar
If thats the case, I just through one away. Pretty easy to replace just be careful with the ribbon.
Old 08-26-13, 07:17 PM   #9
O. L. T.
Keeper of the light
Trader Score: (15)
O. L. T.'s Avatar
ODO doesn't work, but the search button does http://www.clublexus.com/forums/sc-4...tml#post668356
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Odometer question 92 LS400 dicer LS400 11 09-30-14 12:53 PM
Odometer display is blank Brando ES300 and ES330 0 09-02-13 04:39 PM
2006 odometer in 2004 dashboard!! would it work? Turboo SC 430 15 02-17-13 12:35 AM
98 GS300 - odometer not working anymore SuicidnS13 GS - Second Generation 2 09-06-11 07:57 PM
Converting Miles To Kilometer Odometer jadeboy IS - Second Generation 4 08-13-07 07:21 PM
Tags
1997, 400, blank, lexus, ls, odometer, sc400, screen, sensor, speed
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
