SC- 1st Gen (1992-2000)
Melted Positive terminal
Old 08-21-13, 10:26 AM
sj408
sj408's Avatar
Default Melted Positive terminal
Hey guys, so the past few weeks when i get in the car every once in a while there will be no power to anything. When i go by the battery and move the cable going to the fuse box it all kicks back on.
Now i open the fuse box and the positive terminal that hooks into it has literally melted the plastic around it.
gonna try and get a pic but what would cause the positive to get so hot it would melt?
Old 08-21-13, 10:39 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I say a bad ground somewhere or something is staying on for way to long, creating a hot terminal.
Old 08-21-13, 11:07 AM
thm8d
thm8d's Avatar
Agreed!^^^
Old 08-21-13, 12:42 PM
sj408
sj408's Avatar
So i noticed somehow the positive worked itself loose, is that the cause of the melting? or a result?? Im thinking maybe the positive never had good connection and was just bouncing back and forth under the screw.
tightened it up and hopefully no more issue, just weird it was even loose
Old 08-21-13, 12:59 PM
Ali SC3
Ali SC3's Avatar
yes any gap in the conductive surfaces will create arcing when it moves, and it will melt it and whatever happens to be around it. make sure its tight for good this time, it is odd it even came loose unless it was removed at some point.
Old 08-21-13, 08:13 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
You hit right on the hammer. ^^^^^^^
Old 08-21-13, 09:35 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
The nail...he hit the hammer on the nail.
Old 08-22-13, 02:35 PM
Dx3
Dx3's Avatar
I lol'd
MamadIS
09-26-21 08:35 AM
Spyder78
04-11-16 05:13 AM
subzero32
08-01-14 06:48 AM
ICONYQ
08-31-11 07:22 AM
6SOARER
01-27-11 12:02 PM
Quick Reply: Melted Positive terminal
