The computers behind the panel on the passenger side in the rear. There is a small chip inside the computer that is linked to your key, remove that and swap in your new parts with the old chip and it should work. Have you check some of the common problems? I know there is a thread on this subject about common things to try.
Try using the search function if you haven't check it out already
