SC- 1st Gen (1992-2000)
Chugging Gasoline
Old 06-13-13, 12:18 PM
noondogz
noondogz's Avatar
Default Chugging Gasoline
I recently did the BFI mod to my 96 sc400. I was under the assumption that this was supposed to improve gas mileage slightly. I seem to be getting considerably worse gas mileage than before!
Whenever I start up my car, I can smell gasoline from the exhaust for a little while. I checked for any leaks underneath the car and I can't find any. Anybody know what the problem could be? Could I have possibly screwed up the MAF sensor and now my car thinks to dump more gasoline into the engine than it actually needs?
Old 06-13-13, 03:37 PM
USMC
USMC's Avatar
I did it and no problems. MAF would be my starting point.
Old 06-13-13, 03:51 PM
USMC
USMC's Avatar
If you didn't already do it, you might try pulling the green 30 amp fuse in the engine bay fuse block to reset the ECM. Let it idle for 10 minutes and shut it off, then restart it and take it for a short drive and then shut it off, restart and let it idle for 5 minutes and shut it off.
That should recalibrate the system to the airflow.
Old 06-13-13, 03:56 PM
zzobeyyzz
zzobeyyzz's Avatar
Went through the same situation on my sc300.
Old 06-13-13, 05:13 PM
noondogz
noondogz's Avatar
did you reset the ecu and get the problem fixed?
Old 06-14-13, 11:23 AM
durps
durps's Avatar
You deff wanna reset the ecu when you do mods like this. Reset it and report back.
Alex2jz
Performance & Maintenance
10-02-13 01:37 PM
wheels 2
06-02-10 06:41 PM
kaldES98
04-15-10 05:29 AM
jth3rd
03-29-08 02:36 PM
sweetsc400
05-07-03 04:53 PM
Quick Reply: Chugging Gasoline
