SC- 1st Gen (1992-2000)
OEM Fuel sender ohms range
Old 05-22-13, 12:04 PM
turbodremz
turbodremz's Avatar
Default OEM Fuel sender ohms range
Does anyone have the ohms range for the stock fuel sending unit for an SC300 (92)? Prepping for a few things, and the stock cluster getting replaced with a new setup is one of them, but need the ohms range for a new fuel gauge. Any info is greatly appreciated.
Old 05-23-13, 04:04 PM
LEX_MAN
LEX_MAN's Avatar
https://www.clublexus.com/forums/sc-...esistance.html
Been there still doing it. I just hooked up the low fuel light (got rid of the cluster) so when the light is on i refuel asap .
Old 05-23-13, 07:30 PM
turbodremz
turbodremz's Avatar
Well Im planning an aftermarket cluster setup, so I need the ohms range to make sure I get the correct gauge.
I guess if time permits, I will pop the tank open tomorrow and get the full range. Ill be sure to post up the details.
Old 05-23-13, 07:51 PM
BigManne
BigManne's Avatar
https://www.clublexus.com/forums/per...el-gauges.html
Old 05-24-13, 10:54 AM
turbodremz
turbodremz's Avatar
Exactly what I needed, thank you
Old 05-24-13, 02:05 PM
BigManne
BigManne's Avatar
no problem
Yohan84
SC400 / 300 Classifieds
09-16-14 10:38 AM
KahnBB6
12-06-11 03:18 AM
KahnBB6
11-08-10 01:11 PM
Twix
20
03-27-10 10:21 PM
BostonBill
12
11-15-07 10:46 PM
Quick Reply: OEM Fuel sender ohms range
