SC- 1st Gen (1992-2000)
Converting cornering lights - foglights question
Old 12-31-02, 03:50 PM
LexusBiz
LexusBiz's Avatar
Default Converting cornering lights - foglights question
I read Rich ****'s very useful website detailing on how to convert pre-95 SC cornering lights into fog lights. Thanks Rich.
Question I have, would it be possible to throw in a rocker switch into the wiring to create a driver operated button to turn the lights on and off.
I was thinking of wiring the lights into the city lights. And figured I could add a switch, therefore I could turn on the city lights/driving lights without having the fog lights turn on if need be. And be able to turn on the fog lights when the city lights are on.
I am assuming I can throw the switch into the wiring running between the city light positive wire t-tap and the 86 spade.
Will this work, please advise.
Thanks
Biz
Old 12-31-02, 04:05 PM
lex400sc
lex400sc's Avatar
A switch should work anywhere in the circuit, although I would recommend you do run it off a low voltage source or ground like you said. I was going to use the stock stereo system's power/volume **** since it isn't really doing anything now. With that ****, I was thinking I could run the fog ground over and use it as a dimmer switch, which would serve no real purpose, but a cool mod anyway .
Old 01-02-03, 08:18 AM
Manaray
Manaray's Avatar
Rich, is it better to put the swich on the ground side or just get a relay and run the switch on the positive side...?
Old 01-13-03, 01:49 AM
Bentley1
Bentley1's Avatar
What's the URL to Rich ****'s web site? If this is not permitted, please PM me with the URL.
Thanks
Old 01-13-03, 03:05 AM
lex400sc
lex400sc's Avatar
Manaray, you can actually put the switch anywhere in the circuit, shouldn't matter at all. I'd do it on a low voltage source just because I hate getting shocked more than anything.
Bentley, http://www.intellexual.net/faqframes.html
TRD soarer
12
12-16-07 02:24 PM
vince1128
12-29-06 08:20 AM
KKRlexus
IS - 1st Gen (2001-2005)
04-17-06 05:06 PM
rawdog
03-08-06 11:46 AM
Quick Reply: Converting cornering lights - foglights question
