SC- 1st Gen (1992-2000)
Wood Trim Refinish Job
Old 05-08-13, 08:48 AM
Ozzzzy
Ozzzzy's Avatar
Post Wood Trim Refinish Job
As I stated in a previous post, my wood trim is a mess from lack of care from the previous owner, moisture, and sunlight. I was given recommondations on what to do and was asked to post my attempt to make them presentable again so here I post. These wood pieces were taken out an SC from a pick a part place. My wood trim is actually far worse than these. I was told to start with sanding with 1000 grit sandpaper being very careful not to go too fast seeing that the the veneer is only 1/32nd of an inch thick.
Old 05-08-13, 08:52 AM
Ozzzzy
Ozzzzy's Avatar
OK, after 10 minites and two sheets of 1000 grit sandpaper, I've made NO progress. I might as well have been using notebook paper. I'm going to get the next 2 higher grits tonight and try again
Old 05-08-13, 09:39 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
I'm interested on seeing how this comes out.
Old 05-08-13, 10:42 AM
93Gotjuice
93Gotjuice's Avatar
Same here haha...
Old 05-08-13, 12:28 PM
Boxxx
Boxxx's Avatar
Once you've sanded it down to the wood you should be able to apply a clear finish to give it the smooth and shiny look. If there's still finish on the wood you could try using chemical strippers or heat to remove the coating. You could use exterior wood polyurethane gloss finish, that'd protect the wood from UV rays and give it the glossy look it originally had.
Old 05-08-13, 02:44 PM
Biddles
Biddles's Avatar
I thought I read hitting it with 2500 grit until the sun damage is gone and you're good to go...
Old 05-08-13, 04:07 PM
1WILLY1
1WILLY1's Avatar
1000 grit wont do anything, also you dont need to sand down to the bare wood, in fact that the last thing you want to do.
Sand it with 320 grit, then go to 400, then spray it with a good quality lacquer based clear coat.
Your moisture marks should be gone and it will be back to new(pending you do a good job lol)
Old 05-08-13, 04:58 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I am in for the result.
Old 05-08-13, 05:17 PM
jayclapp
jayclapp's Avatar
The original finish is polyurethane varnish. The best bet to remove the old finish is probably varnish remover and steel wool. Using steel wool will allow it to conform to the compound curves and less the change of going thru the veneer.
Once the finish is removed and sanded smooth, you might choose to bleach the wood, finish sand smooth again, and then apply a stain. This will allow all the pieces to have the same color when done. Looks like you have multiple colors now.
I personally wouldn't put lacquer on top of any residual varnish. I'd stick with polyurethane varnish.
Old 05-08-13, 05:29 PM
Ozzzzy
Ozzzzy's Avatar
In my previous post about the wood trim problem, someone stated that they tryed using varnish remover and a different remover and it didn't even touch the old finish.
Old 05-08-13, 06:12 PM
Boxxx
Boxxx's Avatar
You have to use a Methylene Chloride or Methanol based stripper for polyurethane.
Old 05-08-13, 09:05 PM
Ozzzzy
Ozzzzy's Avatar
So I went and bought 3M 150 FINE grit sandpaper. Worked great! Did about 20 swipes, wiped away the dust with a rag, and just repeated until I got down to wood. It took about 5 minutes with the 150 grit, then went at it with the 1000 grit to smooth it out. As you can see in the photo, I have to be careful around the corners as I went through the veneer in that little spot but.........
Old 05-08-13, 09:08 PM
Ozzzzy
Ozzzzy's Avatar
using a some brown paint mixed with just a little black paint, dabed on with a fine brush, tou have to look very closely to tell there is any difference between the wood and the touch up. I sanded with the 1000 grit after I took the picture, it blended perfectly. Now I just have to repeat 6 times.
Old 05-08-13, 10:25 PM
Boxxx
Boxxx's Avatar
Hey, not so bad so far.
Old 05-09-13, 07:08 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Looks pretty good so far. To bad you nipped that corner...
Quick Reply: Wood Trim Refinish Job
