SC- 1st Gen (1992-2000)
which should i go with?
Old 05-02-13, 04:12 PM
grumpi300
grumpi300's Avatar
Default which should i go with?
i really need help guys. i took off my fan shroud, and mechanical fan assembly to install electric fans. so next i need to decide which fan shroud to go with. i'm fairly certain these options will fit, if not directly then with a little welding to make a different bracket. seeing as these are for the supra, the sc and the supra radiators are pretty close, i needed to see which would be a better fit for the sc. here are my options.
http://thmotorsports.com/mishimoto/m.../i-226059.aspx
http://thmotorsports.com/mizu/mizu_r.../i-305827.aspx
im completely loving the mishimoto shroud with its cleaner aluminum look and space. but theyre 12" fans as opposed to the mizu fans. the mizu fans look a little too big. also the mizu shroud looks like its more of a direct bolt on as opposed to the mishimoto shroud has the holes facing upward instead of towards the radiator. thanks for the help guys.
grumpi300
06-07-13 04:17 PM
sj408
Performance & Maintenance
04-25-13 05:20 PM
JohnnyB822
09-08-10 12:18 PM
celiman05
01-15-09 05:57 PM
Quick Reply: which should i go with?
