SC- 1st Gen (1992-2000)
LED Brake Lights
Old 04-24-13, 04:03 PM
noondogz
noondogz's Avatar
Default LED Brake Lights
Just replaced my old cracked tail light with a brand new tail light assembly that I got from ebay. Only problem is that a couple of the bulbs are burnt out in the new assembly.
I would take the bulbs from my old tail light and throw them in the new one, however, they are all rusted from the water that got into the assembly from the crack.
I know the bulb size is either 1156 or 1157, but I figure, if I'm already replacing the bulbs, are there LED alternatives that would fit and so my lights could be brighter and last longer?
Old 04-24-13, 04:37 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Absolutely they are....
Check out www.superbrightleds.com
Type your size bulb, more than likely a 1156, an search which LED you would like. They have many varieties to choose from for your different taste.
Old 04-24-13, 05:51 PM
Dougspeed
Dougspeed's Avatar
Just be forwarned that since the voltage that the LED bulbs draws is so low, your bulb out warning light may not turn off since it doesn't see the correct voltage draw that a regular bulb takes.
Old 04-24-13, 05:53 PM
Studiogeek
Studiogeek's Avatar
The ebay tail lights my car came with keeps the bulb out light on 24/7 even with regular bulbs. I cant wait to replace them.
Old 04-25-13, 08:51 AM
Dream36
Dream36's Avatar
you can wire in a resistor along your lights to "fake" the voltage to your ecu. there are also LED flasher relays to help from the fast flash if you arent comfortable wiring in the resistors
chaos6458
01-24-12 08:25 PM
menty
01-30-11 12:26 PM
sarah
RX - 1st Gen (1999-2003)
07-28-09 11:28 PM
Dr. Yellow
08-03-07 09:13 AM
BA_GS400
Lighting
05-22-05 09:55 PM
Quick Reply: LED Brake Lights
