Does this sound about right?
Hey Guys,
I picked up my 97 SC3 w/ 140k miles on her and was told that some of the routine maintenance had been done, but I want to be sure, so, I ordered a bunch of items from Jose at Carson Toyota. (Btw, Awesome guy to deal with) So far, this is what I've oredered and was wondering if I should be ordering anything else. That's where your help plays a big role Thanks in advance Guys!! Much appreciated
Thermostat
Valve cover gaskets
Head gasket
Head studs
Water pump
Oil pump
Tensioner
Timing belt
Accessory belt
Fuel filter
Cam seals
Crankshaft seal
Dist. cap and O-ring
Rotor
Wires
NGK iridiums
Trans mount
Motor mounts
O2 sensor front and rear
PCV valve
Toyota type IV ATF
Mobil One gear oil for differential
Mobil One 5w30
I believe that's all I've ordered for now. I was also wondering what the difference is between the water pump tensioner and an idler bearing.
Anyhow, Thanks again Guys!!
Thermostat
Valve cover gaskets
Head gasket
Head studs
Water pump
Oil pump
Tensioner
Timing belt
Accessory belt
Fuel filter
Cam seals
Crankshaft seal
Rotor
Wires
NGK iridiums
Trans mount
Motor mounts
PCV valve
Toyota type IV ATF
Mobil One 5w30
Lol!! You Guys CRACK me up I ordered all of these parts because I want to be on the safe side. I wasn't sure if I needed more, but from the responses I've been reading, it appears as though I've ordered the majority of what I need. Thanks so much Guys, I knew I could count on the CL community
Hey Guys,
Thermostat
Valve cover gaskets
Head gasket
Head studs
Water pump
Oil pump
Tensioner
Timing belt
Accessory belt
Fuel filter
Cam seals
Crankshaft seal
Trans mount
Motor mounts
Thermostat
Valve cover gaskets
Head gasket
Head studs
Water pump
Oil pump
Tensioner
Timing belt
Accessory belt
Fuel filter
Cam seals
Crankshaft seal
Trans mount
Motor mounts
