Help - cornering lights .....
Need some help in finding the cornering lights for the below front end.
I will be getting the AIT Velocity front end and want to get the cornering lights that fit as similar to the below picture.
If anyone can provide a link or information for these lights that would be greatly appreciated!!!!!
Thanks.
Thanks.
Those are not cornering lights, those are the fog lights that come on 95+ cars.
If you are putting a body kit on that has fog lights on it you will have to buy some fog lights and probably modify your cornering light wiring (there's a couple DIY's explaining how)
So, the stock fog lights will fit the cut out, then? I saw a thread on re-wiring from corner to fog but was not sure I wanted to do that or not.
Appreciate your answer and hope others can elaborate more.
The 92-94 cornering lights are shaped differently than the 95+ fog lights, and they will not fit those cutouts.
It is a '92 and I realize they won't. What I want to do is to find lights that are shaped similar to the ones shown but implement them as cornering lights to avoid the re-wiring if that is possible.
I believe there is an after market offering for AIT and/or Extreme Dimension kits but have been unable to locate the site.
Thanks and please keep the information and ideas flowing.....
Bump..... still looking for some additional info.... Thanks....
You're going to need 97+ sc fog lights, or retrofit intrepid fog lights (theres a DIY for this). 95-96 foglights will NOT fit. I believe there is also another thread on hooking up your cornering lights wiring to work as foglights.
Hope that helps
Hope that helps
Thanks for all of the advice.
Hopefully acquiring the +97 lights won't be an issue as fitment is my first priority.
Whether they end up as cornering or fog lights is secondary so I wil ask the body shop to handle that aspect as either one is fine with me.....
RafyIS300
IS - 1st Gen (2001-2005)
06-28-10 03:26 AM
