SC- 1st Gen (1992-2000)
any way to increase the pedal sensitivity?
Old 12-17-02, 11:24 PM
kylesc400
kylesc400's Avatar
Default any way to increase the pedal sensitivity?
beyond adding parts, is there any way to adjust the sensitivity (thru cabling or what not) of the gas and break pedals so i get more immediate response?
Old 12-17-02, 11:27 PM
Lvangundy
Guest
Posts: n/a
The brake pedal is height adjustable..although it can be a pain to get under the drivers side steering colum to adjust it.
New pads, and new rotors should give the car a more repsonsive feel..stainless steel brake lines will reduce brake fade.
Old 12-20-02, 07:14 AM
Stevenem
Stevenem's Avatar
SS lines won't help fade so much as they take the mushyness out of the brakes. Good fluid will.
As far as adjustments, I haven't received my service manuals or car yet... but I know some SC's are more throttle sensitive than others. Possibly ECU upgrade?
Old 12-20-02, 08:34 AM
SRQ400
SRQ400's Avatar
Talking
Yesterday I had a cold air induction installed and while they we’re at it I cleaned the throttle body. With the engine cover off I noticed that there was considerable slack in the throttle cable. A quick adjustment and WOW instant throttle response. Prior to this I just thought that this is just the way this car is - it always almost fell on it’s face prior to pick up. So check your cable for excess slack they will stretch with time.
Old 12-20-02, 10:40 AM
kylesc400
kylesc400's Avatar
ive cleaned the throttle body but havent had time to check out the cabling. thanks for the tip. is there any way to tighten the slacked cables or do i need new cables? ill have to take a look at this next week
tuztime889
05-02-17 09:50 PM
Lexus082
Suspension and Brakes
10-13-12 05:40 PM
Lexus082
06-21-11 05:39 PM
Lexus082
15
10-17-07 03:39 PM
Lexus400mn
06-04-07 12:26 AM
Quick Reply: any way to increase the pedal sensitivity?
