SC- 1st Gen (1992-2000)
99 sc300 AC turned off and wont turn on
Old 02-24-13, 08:45 AM
2jForce
2jForce's Avatar
Exclamation 99 sc300 AC turned off and wont turn on
My ac randomly just turned off while i was driving and it wouldnt turn back on the screen went completely blank were the AC is this happened to me before same way and we switched out one of the fuses and it came on fine again but now i bought new fuses and swtched out the 10A HTR which is supposse to be the AC fuse but the AC still wont turn on idk what this might be need help !
Old 02-24-13, 12:19 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
You could have tripped a fuse. Did you drop any change into the cigarette lighter? If you did, you could have tripped the fuse out. If the A/C control screen doesn't illuminate, it could be the cigarette lighter fuse. (Incomplete circuit)
Otherwise, I'd just get the original fuse you had in there that caused the A/C to work and put that back in...GL
Old 02-24-13, 12:57 PM
2jForce
2jForce's Avatar
Im not to great with this fuse wiring crap lol but Yeaa I dropped a dime in the cig lighter awhile back and its stuck in there so I should change the cig lighter fuse and try taking that dime out ?
Old 02-24-13, 01:01 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Yeah, that's where I would start definitely...but you said the A/C worked after you placed another OEM fuse into where the busted one use to be? Just get that dumb dime out of the cigarette lighter and check the fuse...I had this same problem. No A/C turned on at all...ended up being the cigarette lighter fuse popped. Hope that fixes it for you...GL
Old 02-24-13, 01:19 PM
2jForce
2jForce's Avatar
OMFG bro you saved my life Lmaoo after hours of taking fuses off and taking the cig lighter apart my AC turned on lol thanks bro !
Old 02-24-13, 01:21 PM
2jForce
2jForce's Avatar
I checked all my wiring everything looked good stupid dime made a week of me almost getting a heat stroke down here in Miami with no AC lol thanks again man
Segzy14
07-18-18 01:00 PM
cheez
03-04-11 07:42 PM
TheBlurr
09-08-10 11:34 AM
BilluAwan
12-07-08 09:20 PM
tuterz
Performance & Maintenance
05-28-08 11:29 PM
Quick Reply: 99 sc300 AC turned off and wont turn on
