Connector Part Numbers
I thought I would post some common connector numbers that I had a hard time finding while restoring my 92 SC400. Most of these turned to dust when I tried to remove them and some do not have part numbers on them. I included a number that is no longer available so if you do a google search with this number you can see what suppliers to stay away from if they show this as available for order. Sewell Lexus is an excellent supplier and very reasonable with our discount and if they can't get it there's a 99.9% chance it is not available anywhere. Any others with connector numbers feel free to post.
Knock Sensor Connector White 90980-11166
Cam Position Sensor Female Right Hand (Passenger Side) Dark Gray 90980-10949
Cam Position Sensor Female Left Hand (Drivers Side) Dark Gray 90980-10947
Coil Conector Female Attaches to Coil Black 90980-11246
Engine Coolant Temperature Connector Female Green 90980-11062
Fuel Injector Connector Female Dippon Denso F1 needs new terminals too. Will not work with existing terminals. Available from a variety of retailers
**Knock Sensor Wire Harness (no longer available) 82219-50010
This is also a great link to show pictures of a lot of the connectors to help in your search
http://www.docstoc.com/docs/55161581...aterproof-Type
New links:
http://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
New links:
These are all GE or GTE.
90980-11400 Starter
90980-11349 Alt
90980-11246 Coil
90980-10532 Oil Level
90980-10711 Tps
90980-10896 Efi Resistor Male
90980-10897 Efi Resistor Female
90980-10947 Crank Sensor 2 Pin
90980-10947 Cam Angle Sensor 2 Pin
90980-11062 Efi Temp/COOLANT TEMP 2 Pin
90980-11428 COOLANT GAUGE
82998-12620 TERMINAL
90980-11077 Fuel Pump Harness 5 Pin
90980-11151 Ignitor 12 Pin PLUG
82998-12440 TERMINAL
90980-11152 Ignitor 4 Pin
90980-11166 Knock Sensor
90980-11362 Fuel Pump Ecu
90980-11428 Dash Temp 1 Pin
90980-11156 Stock Injector NA
90980-11154 Stock injector TT
82998-12440 TT injector terminal(12)
90980-11028 main o2 harness side
90980-11027 main 02 sensor side
90980-11363 oil switch pressure
90980-11246 COIL PACK HOUSING
90980-11153 INJECTOR HOUSING
90980-10845 TURBO PRESSURE SENSOR
90980-11144 IDLE AIR CONTROL VALVE
90980-11428 COOLANT GAUGE PLUG
90980-10897 RESISTOR PACK
90980-11143 SPEED SENSOR
90980-11051 BACKUP/REVERSE SWITCH
90980-11003 PROGRESSIVE STEERING SOLENOID
90980-11271 PROGRESSIVE STEERING SENSOR
90980-10942 4PIN AIR CON PLUG (3 TERMINALS)
90980-11400 Starter
90980-11349 Alt
90980-11246 Coil
90980-10711 Tps
Thanks for the input Oscar. Very helpful. I had a heck of a time finding some of the connector and other part numbers I needed and thought this would be a great resource for others that need them. Anyone else with hard to find connector part numbers please add to the list!
[QUOTE=dogwisper;7764303]I thought I would post some common connector numbers that I had a hard time finding while restoring my 92 SC400. Most of these turned to dust when I tried to remove them and some do not have part numbers on them. I included a number that is no longer available so if you do a google search with this number you can see what suppliers to stay away from if they show this as availafor order. Sewell Lexus is an excellent supplier and very reasonable with our discount and if they can't get it there's a 99.9% chance it is not available anywhere. Any others with connector numbers feel free to post.
https://www.ih8mud.com/tech/WireHarnessRepairParts.php
Diagnostic Connector under the hood for GEN 1 1991 LS400 and others might be one of these:
90980-10530
90980-10778
I really want the PINS I can put into some empty holes to add features to the
TOYOCOM (TOYOBD1) gadget I got to log OBD1 data. Can anyone direct me to these?
I will check into the wrecking yard scene soon I think!
90980-10530
90980-10778
I don't want to knock anyone's hard work and this is some great information, very helpful. I'm definitely saving this list and bookmarking this page....BUT (of course,lol) I'd just like some clarification on a couple part number descriptions. I see a few that just say "Terminal". Could this information just not be found or is it universal? I've listed them below.
Thanks,
plosey93
Thanks,
plosey93
Sorry for the slow response to plosey93es but this original thread was posted 6 1/2 years ago!!! As the internet search has become much more useful in that time I posted illustrations of the terminals in question. The terminals he referenced are for the connectors directly above them. Hope this is helpful. Also I suggest you look at the original post dates on some of these threads if you have any expectations of timely responses.
StarGS3
10-19-17 06:06 PM
11027, 8221950010, 8299812440, 9098011143, 9098011152, coil, connector, housing, ls400, luxes, numbers, part, pins, plug, sc400
