SC- 1st Gen (1992-2000)
Sunroof replacement
Old 12-03-12, 10:13 AM
super400
super400's Avatar
Default Sunroof replacement
Hi. Im new to the forum but been a lurker for some time. Ive done some searching around for my sunroof issue but didnt find a whole lot of info. My 93 sc400 has a cracked sunroof. My dad bought a 92 sc400 about four months ago and then totaled it two months later. He did a 360 into a rock wall on the interstate. Luckily he was ok, the car not so much. Amazingly the engine will still start up even though its sitting in the engine bay sideways. Really hard to kill these cars. So ive been pulling parts off it his to put on mine. Free parts! His sunroof survived the crash and I want to do a transplant. Im just looking for some clear instructions on removal. One thread I saw said I have to take off the two plastic trim pieces on the sides but when I attempted it they really didnt come loose and the entire glass moved. Call me careful, I just dont want to break anything especially if I really need the part.
Old 12-03-12, 10:16 AM
rcchris7
rcchris7's Avatar
Its the trim pieces on the drive and passenger side that you will remove.. I used a razor to get in there but a thin flat head is safer after the 2 trim pieces are popped off it's just 6 bolts to get the glass of. make sure you remember how the glass spacers are positioned so your sunroof will be aligned with the roof of the car nice and flush
Old 12-03-12, 11:32 AM
Kalogerus
Kalogerus's Avatar
Remove the front and rear upper trims (pillars with handles and rear window trims) you'll see screws for the headliner, remove them including the one in the dome light. You then will see screws necessary to disassemble the sunroof.
PS: When you remove those rear window trims, the screws will strip with a normal screw driver, use a pair of needle nose lockjaw pliers to get them loose then remove them from behind the handles with a screw driver.
Edit: Here is the sunroof diagram
Old 12-03-12, 12:28 PM
rcchris7
rcchris7's Avatar
If he's just replacing the glass he won't need to change the whole unit? I ended swapping my entire unit since I couldn't get just the glass from the wreckers so I'm not 100% but it would seem the whole unit can still in place to swap glass
Old 12-03-12, 12:43 PM
sc400ka
sc400ka's Avatar
rip glass out put in cf sheet?
Old 12-03-12, 04:57 PM
over40driv
over40driv's Avatar
I removed my sunroof to conv. to a hardtop. The glass is encased in a fiberglass/plastic housing that is pop-riveted together and should prob. be changed out as a unit. Ive got a good one for$150.00 & shipping.
JonnyO78
10-13-18 03:23 PM
Returd
Performance & Maintenance
05-09-17 05:50 PM
Returd
01-22-17 05:41 AM
718murdoc
02-20-11 01:04 PM
George94
05-10-04 06:45 PM
Quick Reply: Sunroof replacement
