SC- 1st Gen (1992-2000)
Replacing rear hub/bearing
Old 11-26-12, 06:28 PM
VertigoRT
VertigoRT's Avatar
Default Replacing rear hub/bearing
Got new tires today, and confirmed that my steering rack probably needs replacing, as I leak P/s fluid and the bushings looked pretty good. Looks like its the high pressure hose though? The boots looked good to me...
This also confirmed for me that I had a bad bearing in the back. In his words `its got an inch and a half of play`
I bought replacement bearings (Timkin I believe) but noone seemed to sell a hub? Is it probably safe to use the same hub and just swap the bearings?
Thanks!
Old 11-26-12, 06:39 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I am about to tackle this project in the next week or so. I wouldnt see any problem in just replacing just the bearing. I cant find a diy thread in here about it at all.
Thats a hint!!!!
Old 11-26-12, 07:13 PM
OG Dada
OG Dada's Avatar
Oh man, I remember when I did mine... The passenger side was fine reusing the old hub, but when it came to the driver side, it instantly killed the new bearings because the hub turned out to be bad as well, which basically made the job harder 'cause I did it twice on that side. Now I have an extra wheel bearing and a hub from a 300 which has a smaller dust shield compared to the SC400's.
I'd suggest buying a new hub too, just to make sure the old one is bad. Only thing that's gonna make things complicated is, only way to find out if hub is also bad is after installing it in with the new bearing to see if there's still "play".
Old 11-26-12, 07:25 PM
VertigoRT
VertigoRT's Avatar
I havent seen any of the local auto places having them. I lucked out even finding the bearing... Im hoping this is all it is. It is pretty loud though... and annoying... lol
Old 11-26-12, 07:37 PM
mk4lex
mk4lex's Avatar
Same here my hub was bad aswell. Its frustrating to do it twice so take good advice and replace the hub
Bocatrip
01-28-19 02:00 PM
river
RX - 1st Gen (1999-2003)
04-03-16 10:03 AM
M K S
02-11-16 06:43 AM
sivikvtec
Suspension and Brakes
03-13-10 06:51 PM
r3dl4b3l
10-05-09 09:48 AM
Quick Reply: Replacing rear hub/bearing
