SC- 1st Gen (1992-2000)
$300 Dollar SC 400
Old 01-27-15, 11:08 PM
  #91
t2d2
t2d2's Avatar
Man, you really missed a golden opportunity! You should have insisted on paying $400 for it so your handle could be SC$400 or even $C400.
Old 01-28-15, 06:15 AM
  #92
Bankswood
Bankswood's Avatar
I had the exact same issue. I added about a half quart of oil and it fixed the issue. I always put a full 6 quarts in my 400 now and the issue has never happeded again.
Old 01-28-15, 06:18 AM
  #93
Bankswood
Bankswood's Avatar
Originally Posted by kmoore737
Update on our $300 SC 400. My son got his license in Dec 14, loves driving the car. 4k miles since it was "reborn" in our garage 18 month ago. Almost all the miles were driven by him with me in the right seat teaching him to drive. However we have a new issue. The low oil level sensor illuminates on hard left turns only. Oil level is good and only on hard left turns...any ideas?
Old 01-28-15, 08:52 AM
  #94
kmoore737
kmoore737's Avatar
This is first time this has happened and the oil level is at the top of the full mark. I am guessing there is an issue with the oil level sensor itself. Does anyone know exactly where it is located on the 400?
Old 01-28-15, 09:35 AM
  #95
SC400slide
In Recovery Mode
SC400slide's Avatar
I got the same issue...the oil level sensor is beside the oil filter, near the base of the filter. They usually don't go bad but maybe in your case it has. Make sure the connections are clean before replacing.
Man...$300
Old 01-28-15, 02:08 PM
  #96
Bankswood
Bankswood's Avatar
My dipstick also showed full. I added the half quart of oil (assuming you started with 5.5 quarts) and there was no change in dipstick reading but it fixed my issue. As Slide said I doubt it is your oil level sensor. That was about 20k miles ago and 4 oil changes
Old 01-28-15, 03:42 PM
  #97
kmoore737
kmoore737's Avatar
Got it..thx will check connections then bump up a half a quart
Old 02-05-15, 07:01 PM
  #98
kmoore737
kmoore737's Avatar
Default slow battery drain
Got a slow parasitic battery drain. What are the usual items that cause a drain?
4rcedfed
SC400 / 300 Classifieds
04-12-19 10:14 PM
kmoore737
12-30-12 05:38 PM
Quick Reply: $300 Dollar SC 400
