SC- 1st Gen (1992-2000)
Driftech's 2013 Pro-Am Rebuild
Old 11-06-12, 04:19 AM
jwin
jwin's Avatar
Think that 1jz has bad compression in some cylinders. It's for sale in the classified. Wish you were in Texas I would pick it up
Old 11-06-12, 01:12 PM
severendvr
severendvr's Avatar
I like this, keep it up
Old 11-06-12, 01:43 PM
sc400ka
sc400ka's Avatar
how much weight have you shaved off the hog?
Old 11-07-12, 05:08 PM
BigSticks
BigSticks's Avatar
Originally Posted by drewdizzle
Sounds like your maxed. I'd like to see a pic full lock. My next move was to extend my lower control arms. so maybe try that before you spend 2K. I was thinking the same thing, but I just can't fork out 2K, I'm going to try extending the lowers for 100-200$. cut weld.
Well what are you gonna do about tie rods?
Old 12-01-12, 10:14 AM
drewdizzle
drewdizzle's Avatar
Update. I'm back to work on this, I took a vacation and a couple weeks off.
Yesterday I removed the entire body harness. Today I'm going to get into the doors and pull out the windows motors and support. I am looking for a 2jzge right now. finally made my decision. I am going the 1.5j route. make use of one of my few sponsors and put some cp pistons in a ge block.
Old 12-01-12, 10:15 AM
drewdizzle
drewdizzle's Avatar
I believe all you need is to lengthen them, I know pfiefer already has set up his car with lengthened lower arms so I am just going to run his set up. once I get this set up I will post some pics.
Old 12-01-12, 10:16 AM
drewdizzle
drewdizzle's Avatar
Last I checked she weighed in at 2975. I will make sure to weigh her again ofter this.
Old 12-01-12, 01:07 PM
SEXC
SEXC's Avatar
What have you taken off so far to get it to that weight? Post some pictures of interior and exterior when you get a chance. Good luck on the build
Old 12-02-12, 05:57 PM
drewdizzle
drewdizzle's Avatar
Just bought a 2jzge block for the 1.5 build. did some research last night and decided that it is not worth it to find a 2jzgte block. the difference between the 2 blocks being gte has oil squirters and oil feed lines tapped. Since I am going to run forged pistons that can handle the heat and I believe from what i read that the piston needs to be designed to make use of the oil squirters which only stock pistons are so not a benefit. also I have read a difference between the blocks are the oil pump, which I am going to buy a new pump so no big deal there.
next move is to disasemble the 2jzge block and my old 1jzgte, going to do that next saturday at Sideways Performance. My friend Spencer is going to supervise my disassembly, since this will be my first full engine tear down.
than after that I need to send the block in to a machine shop. so not sure if I will just take it to spencer's machine shop or find my own. problem I have is I don't know who to trust on this one.
Old 12-10-12, 10:33 AM
drewdizzle
drewdizzle's Avatar
I tore down that 2j block I bought on saturday, looked very clean. ordering my pistons today, CP Pistons 8.5 CR +.5mm. Also getting some eagle rods ordered and will be ordering all the ARP Head Bolts and Main Bolts.
Old 12-10-12, 10:55 AM
99SC42
gte & na-t
99SC42's Avatar
I am glad you took the advice!
I can't wait to see what it does!
If i were you, I would bump the compression alittle bit to maybe 9.0 or 9.5.1 but either way gl with the project !
Old 12-10-12, 10:59 AM
drewdizzle
drewdizzle's Avatar
I was considering that, CP makes a 9.0 to 1. the only problem is I believe that the 1j head on the 2j block raises compression. also I don't want to run race gas, that is just going to make my track days more expensive and if I bump the compression up won't I need to run a higher octane race gas? all I have out here in california is 91 octane.
Old 12-10-12, 11:13 AM
99SC42
gte & na-t
99SC42's Avatar
Yes it does!
Yes you will need a higher octane, race gas or E85.
Sorry i forgot that you live in CA lol 91octane.
Old 12-17-12, 12:13 PM
drewdizzle
drewdizzle's Avatar
I finally ordered the bulk of my parts today. yikes. what a huge bill. went a little something like this.
Part PRICE PART # Place of Purchase
CP Pistons 674 CP Carrillo
Eagle Rods 464 CRS5590T3D Autoplicity
ACL Rod Bearings 82 6B8100H-STD Phase 2
ACL Main Bearings 92 7M8103H-STD Autoplicity
ACL Thrust Washer 18 2T8103-STD Autoplicity
ARP Head Studs 125 203-4205 Autoplicity
ARP Main Studs 110 203-5405 Autoplicity
1jz Valve Seals (intake) 28.8 90913-02123 Driftmotion
1jz Valve Seals (exhaust) 27.6 90913-02088 Driftmotion
1jz head gasket 200 11115-88410 Estimate
2jz Rear Main seal 31 90311-90006 Carson Toyota
2jz Front Crank seal 11 90311-46001 Carson Toyota
2jzgte water neck & bypass tube 83 16331-46050 Carson Toyota
2jzgte timing belt tensioner 59 13540-46030 Carson Toyota
2jzgte idler pulley 40 13505-46041 Driftmotion
1jz cam seal 20 90311-38041 driftmotion (10 ea)
Oil Pump 170 15100-46052 Carson Toyota
Water Pump 125 16100-49846 Carson Toyota
Timing Belt 27 13568-49036 Carson Toyota
Cams 439 BC0331 From BC
Cam Gear 168.75 BC8830 From BC
Painless Wiring kit 270 50001 autoplicity
I think I did a decent job of bargain hunting, but this bill is still very high.
Once I get all the parts I will take a picture of all maybe in the shape of a christmas tree.
merry christmas to my obsession.
Old 12-17-12, 12:23 PM
99SC42
gte & na-t
99SC42's Avatar
Since you are running a built GE block without oil squirters , you need to get a 96-2000 SC300 Oil pump to have the correct Oil pressure.
Nice parts list you go there, and i bet it wasn't cheap!
Quick Reply: Driftech's 2013 Pro-Am Rebuild
