Installed front O2 sensors now gas gauge stuck on Empty
Any one have any ideas what could be causing this? Its not the cluster, I installed a new one two weeks ago.
I have a 1992 sc400 and have replaced all 4 O2 sensors twice since new and have never had your problem. Now, you said the cluster is new? why do you think the gauge can't go bad? I would start with a loose wire when you installed it, but I would not start blaming the O2 sensors. Try taking out the cluster and looking at the connections. Good luck!
tracked it down i guess when my mechanic had the car he put some fuel in and didnt put the cap back on properly and im not sure but maybe air got in.... i drove about 10 miles and the gauge moved where is should be. thanks and sorry for the false alarm!!
