Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300
Sign in using an external account
Register Forgot Password?
R154 with Tripod doesn't fit into 92 SC300...Why?
Thread Tools Search this Thread Display Modes
Old 08-27-12, 11:17 AM   #16
99SC42
gte & na-t
Trader Score: (44)
99SC42's Avatar
Quote:
Originally Posted by SFrymyah View Post
Automatic cars did not have a shifter hole.
They do have a shifter hole, , shifter bolts down to the tunnel and the lever comes out and bolt to the shifter rod and the shifter rod goes to the side of the trans it's held on there by a 12mm bolt.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
99SC42 is offline   Reply With Quote
Old 08-27-12, 11:34 AM   #17
SFrymyah
Trader Score: (4)
Quote:
my bad, i'll fix the post. I had a DSM brain fart
SFrymyah is offline   Reply With Quote
Old 08-27-12, 11:56 AM   #18
99SC42
gte & na-t
Trader Score: (44)
99SC42's Avatar
^^^^ LOL , it's cool bro!
Old 08-27-12, 12:18 PM   #19
Ali SC3
Na-T Guru
Trader Score: (10)
Ali SC3's Avatar
are the tripod chaser and soarer trans the same length? or is one more desirable than the other?
__________________
1995 Lexus SC300 5spd Na-T ( TT Ecu Mod + a few others)
Ali SC3 is offline   Reply With Quote
Old 08-27-12, 12:53 PM   #20
99SC42
gte & na-t
Trader Score: (44)
99SC42's Avatar
^^ Yes same length.
Then 1st Gen Soarer , then MK3 r154
So for your car is it's 95 and Original 5 speed, the 2nd Gen Soarer and Chaser will be PNP and the mk3 with shifter housing extended properly about 3.5" will be PNP for you car.
The 1st Gen Soarer will non be PNP you will have to cut your Tunnel.
If you have an Auto you will have to cut you tunnel regardless .
Old 08-27-12, 01:21 PM   #21
Cebo
Trader Score: (0)
Finally a good read haha. So from what I've gathered, my 99 auto will need either a mk3 extended(btw is that the whole sc300 front and mk3 rear ive read about? Just to clarify). Or the 2nd gen soarer/chaser. But regardless cut the hole?
Cebo is offline   Reply With Quote
Old 08-27-12, 02:27 PM   #22
Ali SC3
Na-T Guru
Trader Score: (10)
Ali SC3's Avatar
yeah i think with most of the auto you will end up cutting the hole.
basically you have to extend the mk3 trans regardless.
once you get the trans in just see then where you need to cut.
the front and rear stuff is usually when people are talking about mating the driveshafts to get the correct length.
__________________
Old 08-27-12, 02:57 PM   #23
99SC42
gte & na-t
Trader Score: (44)
99SC42's Avatar
Quote:
No it's SC300 rear with MK3 Front half.
Old 08-27-12, 03:00 PM   #24
Cebo
Trader Score: (0)
Cool, thanks guys. I can't wait til I'm fully swapped over. This auto is killing me
Old 08-27-12, 11:09 PM   #25
BoostLee
Trader Score: (0)
Well, the trans is in. I had to cut out more than I expected to get it to be clean... on reflection, I probably could have addressed the tunnel with a big hammer... hindsight, blah, blah.
Thanks for the info you guys!
BoostLee is offline   Reply With Quote
Old 10-24-12, 03:38 AM   #26
Daddy03
Trader Score: (0)
you need to replace the sub tunnel for the tripod
Daddy03 is offline   Reply With Quote
Old 10-24-12, 05:59 AM   #27
Vrank
Trader Score: (4)
Vrank's Avatar
If you check out some supra sites where they do auto to manual swaps on the mk4, the trans tunnel is different and they (when doing it right) buy the stamped steel piece of the tunnel from a 6spd car and use a number of ways to bolt it in. You cut the hole, then fit this over. It adds height to the original. Tripod shifter to me actually has a more desirable fitment in the car. My opinion. I just used self tapping screws and some metal to cover the holes as a temp fix because I found all this out on the fly and the car needed to run and couldn't wait for a "perfect" solution. Eventually I'll buy the mk4 tunnel piece from Toyota and use it on the sc. I watched Ryan V use it on his supra in person, and have no doubts it could work on the sc too.
Vrank is offline   Reply With Quote
Old 10-24-12, 06:21 AM   #28
99SC42
gte & na-t
Trader Score: (44)
99SC42's Avatar
^^^Yes MK4 tunnel works great , and the fitment is 100% OEM.
Old 10-24-12, 08:27 AM   #29
97-SC300
Trader Score: (14)
97-SC300's Avatar
You either need the 95+ SC300 manual tunnel or the Supra 6spd tunnel. It's the same part.
__________________
1997 SC300 Platinum/Black | 2JZGTE | 550CC | USDM cams/turbos | V160 | 6spd 3.13 Diff | PHR 3.5" one-piece driveshaft | PHR 4" Custom Exhaust | RMM DP | RPS Twin Carbon | Mines ECU | Cusco Zero2e Coilovers | Daizen Sway Bars | TSX HID Retrofit | Brembo GT 6/piston front | TT rear BBK | Work Meister S1-CCW Classics | TT Radiator | Katzkin Seats | Vertex Side Markers | Dynamat equipped
97-SC300 is offline   Reply With Quote
Old 06-04-14, 01:01 PM   #30
Aristoman
Trader Score: (1)
Hi Guys, Sorry to revive an old thread.
I have a 97 SC300 manual which came with the W58 that has a tripod shifter. I blew the W58 the other day and I have a 92 soarer R154 transmission (which came from factory with the housing a bit extended and also has a swan neck shifter that goes backwards).
My question is am I gonna have to cut the transmission hole forward in order for this R154 to fit?
Thanks
Aristoman is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Looking to do a r154 or w58 manual swap? look in here, dont make a thread. Cleanshots Performance & Maintenance 150 01-27-14 06:23 PM
Searched TO DEATH: 1J + Supra/chaser R154 = Which shifter??? boostd4 Performance & Maintenance 9 04-02-13 09:15 AM
5spd swap shifter/trans problem need help thebadz32 Performance & Maintenance 4 08-17-12 04:06 PM
craaaazzy's W58 to R154 swap craaaazzy Performance & Maintenance 94 03-24-11 07:13 AM
Which tranny mount for R154 and 2jzgte? DJ420a Performance & Maintenance 6 04-26-10 02:54 AM
Tags
1st, 2nd, 9294, driveshaft, gears, gen, r154, regular, sc300, shifter, style, swap, switched, tripod, w58
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
