SC- 1st Gen (1992-2000)
Extended stud problem
Old 08-25-12, 02:59 PM
hihopes
hihopes's Avatar
Default Extended stud problem
Today i went to install my ARP extended studs in the rear. I got everything apart and ran into a little problem. The emergency brake is in the way.
I figured what the hell and tried anyway. Smacked one stud out. There wasnt much room behind the hub. So i took the extended stud and treid to wedge it in every way possible, but it just wouldnt fit. Its not even that the brake is in the way, the metal backing is too close to the hub for the stud to fit.
This was about the closest i got to getting it through
I know people have installed these studs before so howd you guys do it?
Anybody have any techniques/ideas to throw my way? The e brake looks like a pita to take apart so im not sure if thats the beat idea.
Old 08-25-12, 03:44 PM
k7q
k7q's Avatar
i wedged mines through, but i was using ichiba studs. 55mm i think. just play with it a little.
Old 08-25-12, 03:49 PM
xxtoobsxx
xxtoobsxx's Avatar
Drop e brake handle. Rotate hub and it will fall out.
Old 08-25-12, 03:54 PM
hihopes
hihopes's Avatar
I dropped the e brake and i spun the hub. No luck. Im trying to get it in, no problem getting it out.
And ichiba studs are much shorter.
Old 08-25-12, 04:18 PM
OG Dada
OG Dada's Avatar
Just try to find the angle, don't get stuck in one place. A lot of people have done it a thousand times, including me. But I must warn you, those ARP studs are prone to stripping. Good luck.
Old 08-25-12, 04:30 PM
hihopes
hihopes's Avatar
Yeah i saw that you had problems with yours, but ive seen more good reviews than bad so i gave it a shot.
Anyway, Do you remember if you angled it at the top/bottom, left/right side?
Old 08-25-12, 05:45 PM
OG Dada
OG Dada's Avatar
I didn't really have a hard time inserting it so I don't really remember exactly how. But I had a 15mm spacer so that's Pretty long too. What I remember though when doing it was I was rotating the hub while inserting it...
Old 08-25-12, 06:31 PM
hihopes
hihopes's Avatar
Yeah i feel like i tried every which way. I tried in between every space and turned the hub all kids of ways. But the back of the ebrake is too close for any angle cause the studs so long.. I think i remember reading it was 2.6in which is about 66mm.
Im gunna give it another try in next time i get some time. Maybe i just wasnt trying hard enough.
Old 08-26-12, 05:13 PM
LEX_MAN
LEX_MAN's Avatar
I had mine installed from the bottom. Theres a place to slip the stud in, but i cant remember ,its been a while.
Old 08-27-12, 01:20 PM
jintei
jintei's Avatar
I removed all the e-brake assembly, more space to work on, and put it back together. Easy.
Old 08-28-12, 11:55 AM
hihopes
hihopes's Avatar
thanks for the advice. ill check this out when i get some time
i was thinking about doing this but it looks like a real pain to take it apart. but i guess if i cant find a spot to fit it in, it might be my only choice.
Old 08-28-12, 01:12 PM
Ali SC3
Ali SC3's Avatar
well its a good time to do your ebrake shoes if you have to remove it.
Old 08-28-12, 04:22 PM
hihopes
hihopes's Avatar
do they look worn down badly?
Old 08-28-12, 09:07 PM
Ali SC3
Ali SC3's Avatar
Generally any time you have to take it off is a good time to check at least as they don't come off very often.
I can't tell from the picture exactly but they look ok
Old 08-28-12, 09:17 PM
hihopes
hihopes's Avatar
yeah i feel you on that. id rather put that money towards something that needs attention if the ebrake is in good shape, but thanks for looking out.
Quick Reply: Extended stud problem
