SC- 1st Gen (1992-2000)
Greetings, 1JZ swap beginning
Old 09-03-12, 02:14 PM
jaysus101
jaysus101's Avatar
Good luck with your build
Old 10-05-12, 05:17 PM
GTX580
GTX580's Avatar
Been overwhelmed with work for the Great State of California, plus I had the luxury to deal with smog for 2JZGE.
Spent almost 2 weeks dealing with smog, I had to put the 2J back in my car and smog. In addition, I failed smog due to my EGR being clogged, so after cleaning it plus adding some acetone, I was able to pass smog. Also big thanks to some SAC CL members for hooking it up.
Received harness from Dr. Tweak, time to get to work.
Front turbo, very little shaft play. Whew!
Rear turbo had some black **** around the turbine. I hope this is not a problem.
took me a while to find this Greddy ****
Actually pretty clean overall on the intake side, but the engine had been sitting in storage for a LONG time from what I can tell.
My motor did not come with MAP. Bought the motorola 2.5 bar. Also bought a 1JZ oem map thru CL. I will also test if the motorola map can work with the 1J ecu.
Dropping motor in next week once my clutch arrives.
Old 10-05-12, 05:53 PM
levie
levie's Avatar
very nice. hope the swap goes good for ya. so happy i dont have to deal with smog up here in alberta.
Old 10-06-12, 12:01 PM
megamax
megamax's Avatar
pm sent and good progress??
Old 10-06-12, 12:31 PM
kez
kez's Avatar
******.up a sc400 power steering resivour if you dnt have one yet
Old 10-06-12, 01:01 PM
GTX580
GTX580's Avatar
I bought the driftmotion PS Res, I need to figure out how to mount it still.
Old 10-06-12, 04:01 PM
Joey-E
Joey-E's Avatar
GL with the build
Old 10-29-12, 10:03 PM
GTX580
GTX580's Avatar
All done with swap, no CEL, no 3k problem, no boost leak, Tach soldered.
Just had a 3inch exhaust done at local muffler shop, will post lots of pics soon after I fix the droning problem at low rpm.
Old 10-30-12, 09:46 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thats great news man. your one of the few that havent had any problems and everything worked great!! More pictures of the install...
Old 11-01-12, 10:05 AM
DoomLight
DoomLight's Avatar
Gosh... nothing to look at. You finished it so fast. Not many pics
SuicidnS13
36
07-12-10 07:12 PM
mr_mkelly
02-01-10 06:57 AM
9secCivic
Performance & Maintenance
01-05-08 02:23 PM
hemogoblin
CL of Southern California
18
05-03-06 03:20 PM
Quick Reply: Greetings, 1JZ swap beginning
