SC- 1st Gen (1992-2000)
My LED Door Handle Mod
Old 11-24-13, 08:17 AM
  #46
Luxor
Luxor's Avatar
Originally Posted by koolcat
Thanks for posting this idea. I just did it to mine.
Very cool! Let us see how it looks.
Old 11-24-13, 12:38 PM
  #47
bigwes
bigwes's Avatar
This is a nice mod. I like it. What alarm system do u have on ur car?
Old 11-24-13, 02:04 PM
  #48
scENFORCER
scENFORCER's Avatar
I wonder if this can be made to work with the push-start and smart-entry system I'm looking to install in my car.. Have the door-handle lights light up when the car is unlocked as I approach it.
http://www.advancedkeys.com/Prod_AK104B.html
Old 11-24-13, 06:06 PM
  #49
Luxor
Luxor's Avatar
Thanks, I have a Viper 2-way paging alarm.
That would pretty cool feature. Looking at the diagram, the smart-entry sends a signal to the door switch, not sure if it just unlocks the door or also allows the dome light to turn on as well.
Old 11-25-13, 03:15 AM
  #50
koolcat
koolcat's Avatar
Here are some pictures and videos of it installed, sorry didn't take any during the process. I also have the viper 5901 2-way alarm. The installation is pretty much straight forward with what Luxor has posted.
One of hard part was to run the wire through the rubber hose to the driver side kick panel area from both sides. The second hardest part of the mod was to run a relay for the dome light supervision wire. You need to run a relay for this because I ask this guy that do alarms and he told me to put a relay. He said the relay deals with higher amp to low output or something like that. It is just safer in my opinion to do so.
Just look up dome light supervision in google pictures and you can see diagrams of it. You also need to figure out if your system is a positive or negative trigger because the relay will be wired differently. Wiring took me at least a good 10hrs or so to research and do it. This is only because I didn't setup my alarm, a shop did it before and I had to basically do trials and errors to figure it out. My recommendation is to get dome light supervision to work first then connect LEDs of what ever you need to light up when you unlock the doors.
So now everytime I unlock my doors or open them, the handles and dome light will light up for 30 seconds. You can see this in the videos I uploaded.
Once again thanks Luxor for this great idea.
Old 11-25-13, 08:50 AM
  #51
Luxor
Luxor's Avatar
Koolcat, nice job! I agree, getting the wires routed is the hardest part of doing this. The LEDs you used look very bright!
No relay is needed if you are only using the dome light supervision wire to power the LEDS since LEDs generally have a draw of around 20mA and my alarm can handle up to 200mA output.
Thanks for posting the pictures and videos, I bet your car gets a lot more attention now at night!
Old 11-25-13, 09:01 AM
  #52
koolcat
koolcat's Avatar
I think I used the same LEDs as you. It should give the same output of brightness.
Old 11-25-13, 09:21 AM
  #53
1sWt2GS
1sWt2GS's Avatar
wow looking good very original and clean install
eddie420
04-07-20 11:03 AM
red93sc
RC - 1st Gen (2015-present)
43
12-08-16 10:16 PM
imherenow
41
10-14-13 02:51 PM
HarrierRX300
10-01-04 11:01 PM
Quick Reply: My LED Door Handle Mod
