SC- 1st Gen (1992-2000)
NA-T throttle body question
Old 05-20-12, 04:10 PM
2JTsc300
2JTsc300's Avatar
Question NA-T throttle body question
i modified a gte intake to fit my GE if i removed the two sub-throttle actuators, will that effect anything?
im trying to clean up the stock throttle body and have less wiring
Old 05-20-12, 04:56 PM
Ali SC3
Ali SC3's Avatar
yes, its a common modification, just unbolt what you can, then most people grind down the extra parts and have the small holes welded shut. Some people even enlarge the hole on the sub throttle actuator side, and weld a BOV flange to it (most common i have seen on supras are the tial because they fit easily and are roundish).
you will have to jumper the sub throttle tps pin at the ecu to get rid of the CEL if you are on the stock ecu.
I believe it is jumpered to sensor 5v, so that the ecu thinks its always WOT.
Old 05-20-12, 04:57 PM
2JTsc300
2JTsc300's Avatar
im goin to be running aem ems on my sc300
Old 05-20-12, 05:08 PM
2JTsc300
2JTsc300's Avatar
u know any trends that have them showing that mod?
Old 05-21-12, 08:14 AM
Ali SC3
Ali SC3's Avatar
this is a good example from this thread
http://www.supraforums.com/forum/sho...=1#post7233420
there are some companies that will even perform the modification for you.
http://www.suprastore.com/hksssbovcusi.html
tom steele
Performance
05-19-13 03:27 PM
snomanlex
SC400 / 300 Classifieds
12
10-15-11 07:51 PM
kikaida
10-24-09 04:50 PM
SC30096
Performance & Maintenance
06-03-08 04:23 PM
Quick Reply: NA-T throttle body question
