SC- 1st Gen (1992-2000)
Up & Down Steering Wheel Free Play?
Old 03-15-12, 06:44 AM
TechGreek
TechGreek's Avatar
Question Up & Down Steering Wheel Free Play?
I've noticed that I can bump up/down the steering wheel some and I was just curious to see what could cause this.
I don't see any movement on the shaft going to the rack in the engine bay.
It's almost like it's got half an inch of play ONLY up and down.
Attached Thumbnails Up & Down Steering Wheel Free Play?-screen-shot-2012-03-15-at-8.43.01-am.png
Old 03-15-12, 07:40 AM
horent135
horent135's Avatar
Instruction seems right, any more than that locks the wheel, maybe your wheel lock is broken?
Old 03-15-12, 07:42 AM
TechGreek
TechGreek's Avatar
Not really, everything functions normal (except for the in/out telescopic feature, up/down works without a problem).
There's no recommend fix in the FSM. D'oh
I've got new steering joints from another member I just haven't had the time to put them on.
Old 03-15-12, 08:02 AM
Tabaka
Tabaka's Avatar
I don't think mine plays that much. But when I'm driving at highway speeds and hit bumps on the road, the steering wheel practically rattles...even with my 55 wall tires on stockers. When I put my 19"s on during the summer with 35 walls it drives terrible with steering play. I think it's the rack bushings though.
Old 03-15-12, 08:06 AM
TechGreek
TechGreek's Avatar
My stretched tires don't help. I get the occasional rattle at high speeds depending on what surface I'm on and I think this is what is causing it.
My rack bushings are new daizens polyurethane installed about six months ago.
I don't suppose oil could really mess them up being they are polyurethane as I had a NASTY oil leak.
Old 03-15-12, 07:04 PM
Luxor
Luxor's Avatar
Check to see if your steering column is bolted down all the way, it should be like 4 large bolts.
Old 03-15-12, 09:15 PM
TechGreek
TechGreek's Avatar
I'll take a look for sure. I would be happy it that's all it was because in a rare junk yard car here someone had already taken the entire column out and left it in the there. Went back to get it the next day and they crushed the car after 13 days for a totaled riced out Camry to take its spot.
Old 03-17-12, 10:20 AM
TechGreek
TechGreek's Avatar
I figured it out. The motor over time had loosened it self (the up/down) so I had to use an Allen head and wrench to snug it back up.
I also retorqued to spec the stopper nuts at the top. I'm slightly confused as to what they do because one side has a ground strap which I assume stops something when it gets to high.
The steering wheel feels 100x better. For the first time in a year I was able to take my hands off the wheel at any speed. I also had no problem getting up to 130 MPH on the bridge here whereas normally I feel like my wheel is about to rattle off making me think something was wrong.
I took some pictures. I'll post later on today.
Old 03-17-12, 04:25 PM
xspsi6
xspsi6's Avatar
Hmm I have a friend suffering from the exact same thing in his 92 sc400 with almost 500k miles so I am sending him a link to this thread!
Old 03-19-12, 09:28 AM
TechGreek
TechGreek's Avatar
Uploaded pictures.
Don't torque it down too hard, or else it will strain the motor and possibly burn it up. You just want it snug enough to where there is no slack.
The second picture would be on the exact opposite side of the first picture.
Attached Thumbnails Up & Down Steering Wheel Free Play?-one.jpg   Up & Down Steering Wheel Free Play?-two.jpg
Old 03-19-12, 10:20 AM
Luv2xl
Luv2xl's Avatar
hmm.. i will give this a shot. My steering wheel shows signs of some play and I was considering it to be a bushing located on the steering column..
Good work!
Old 03-19-12, 07:11 PM
plmeeker
plmeeker's Avatar
thanks. ill try that too and then let you know what happenss...
Old 03-20-12, 09:15 AM
Tabaka
Tabaka's Avatar
Man, if this fixes my issue I will take you out for a beer if I'm ever around LA.
****foooking subscribed
Old 03-20-12, 09:48 AM
Biggu
Biggu's Avatar
Ill have to play with mine too, ever since I tapped the wall mine had some play.
Old 03-20-12, 10:32 AM
TechGreek
TechGreek's Avatar
It makes sense to me - the column will get the brunt of the vibration from the rack and loosen it slowly over time. I wonder if this might have something to do with the need for a washer on the inside cover over time.
You're still going to be able to force it up, but it will take a lot of tension on it upwards to hit the stop nuts (it's a safety feature).
If you take both covers off, while you're budging the wheel up and down you'll notice slack between the housing and the nut on the back. I could have put a feeler gauge under the nut on mine so it was pretty obvious what was loose.
Quick Reply: Up & Down Steering Wheel Free Play?
