Weatherstripping
Weatherstripping
I tried searching but couldnt find what i wanted exactly.
Most of the weatherstripping on my sc is dried up and cracked. The seals around the front windshield are pretty fragile, they break & crack almost every time they are touched. Same goes for the side windows. Any solution to this problem or replacement parts?
Front windshield:
Driver Side:
Passenger side (looks like its even separating from the door):
Also, when i close my driver door, the weatherstripping is always peeking out. Some of the clips broke off it looks like. Is it worth it to buy a new piece?
Front windshield:
Driver Side:
So i did some more searching and found the piece around the windshield, part no. 04562.
http://lexus.sewellparts.com/oem-cat...C300-1997.html
also found new pieces for the bottom of the windows, but theyre all pretty highly priced.
does anybody know if the toyota replacement parts are the same? part no. 68170 & 68220 is for the window pieces. They are significantly cheaper so I would rather go that route if they fit.
