SC- 1st Gen (1992-2000)
Just wanted to share my cleaned headlights
Old 02-26-12, 08:16 PM
Acer
Acer's Avatar
Default Just wanted to share my cleaned headlights
I started sanding and polishing my headlights and I'm done with the first headlight.Hope you guys like it.
Attached Thumbnails Just wanted to share my cleaned headlights-get-attachment.aspx.jpg   Just wanted to share my cleaned headlights-2.jpg   Just wanted to share my cleaned headlights-3.jpg
Old 02-26-12, 08:32 PM
XORiGiNaLX
XORiGiNaLX's Avatar
Nice, did you take it apart or just do the outside?
Old 02-26-12, 08:44 PM
levie
levie's Avatar
crazy how much of a difference it makes.
Old 02-26-12, 08:45 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
That looks much better.
Old 02-26-12, 08:51 PM
Acer
Acer's Avatar
Just the outside.
Old 02-26-12, 08:53 PM
cartmill
cartmill's Avatar
damn that looks brand new!
what process did you use?
Old 02-26-12, 08:55 PM
levie
levie's Avatar
looks good, im also restoring headlights, but my seal around the light, or whatever it is, is all mangled, so it has to be re-done and i figure i may as well do the inside and projector lenses, because thats where i think my light is getting all distorted.
Old 02-26-12, 08:59 PM
alex425
alex425's Avatar
Nice job! Looks just as good as new
Old 02-26-12, 09:01 PM
DubbStep
DubbStep's Avatar
Great Job!
Old 02-26-12, 10:01 PM
ashtray
ashtray's Avatar
Really a good job.
Old 02-26-12, 11:39 PM
SJ300
SJ300's Avatar
Damn whhat a difference , what type of sand paper and polishing material did you use if you don't mind me asking
Old 02-27-12, 04:48 AM
Acer
Acer's Avatar
Originally Posted by SJ300
Damn what a difference , what type of sand paper and polishing material did you use if you don't mind me asking
I used 3M wet sandpaper from auto zone. 400,800,1000, and skipped to 2000.I used some Poor Boy's SSR1 polished with my porter cable on a orange foam pad.Start wet sanding with the 400 and work your way up.
Thanks everyone.
Old 02-27-12, 05:05 AM
dirtyjohn
dirtyjohn's Avatar
Looks so much clearer, did you have to using anything to coat/protect after sanding?
Old 02-27-12, 07:19 AM
88supramki
88supramki's Avatar
You should use something to seal it once you are done. After sanding down the yellowed exterior they will just yellow again unless you seal the lens
Old 02-27-12, 01:58 PM
Tabaka
Tabaka's Avatar
Yep, spent hours sanding mine last year. I only used wax to seal and they are completely yellow again. Anyone have a professional "over the counter" sealant that works well for these headlights.
Quick Reply: Just wanted to share my cleaned headlights
