SC- 1st Gen (1992-2000)
IS250 steering wheel in a SC400
Old 02-23-12, 04:39 PM
Zorglub
Zorglub's Avatar
Default IS250 steering wheel in a SC400
Hello everybody, i m new here and already start with silly question !
I wrote SC400 because it's a Lexus forum and don't wanna be impolite talking about Supra , but in fact it's for that car.
So i like to change my steering wheel by a IS250 steering for the look and because i want stereo remote on my wheel.
My concerns:
1. Airbag
I know that in my Supra (=sc400) there is a single stage airbag while in the IS250 it's a dual one.
But why i coudn't simply and quicly change the inflator in the IS250 airbag by the one from my Supra steering as those are same shape/size ?
2. Stereo remote wiring
here i think i only need the slip ring from the IS250 (need it also for the airbag off course). After i will use an aftermarket stereo, so i can problably make myself some harness to it.
3. Fitting
here i don't know, do you think this wheel would fit in my Supra ? the central screw is the same ? any mechanical issue ?
Of course another option would be to go with a SC/GS430 wheel with remote on it...
Old 02-23-12, 04:48 PM
kingnba6
kingnba6's Avatar
well not sure about the airbag or the fitting. but the remote wiring (if getting the 2is wheel and aftermarket unit) you can get a unit like the SWI JACK which you are able to program the stock remote wiring into the aftermarket unit.
Old 02-23-12, 04:57 PM
Zorglub
Zorglub's Avatar
You just solve one of my concern, thank you !
Old 02-23-12, 04:58 PM
kingnba6
kingnba6's Avatar
glad i could help.
and now maybe some more people can help?!?
Old 02-24-12, 08:15 AM
88supramki
88supramki's Avatar
If you have an eclipse unit, no SWIX is required Part of the reason I would like to get one, but you are correct it's a simple connection if you have a different aftermarket unit.
Old 02-24-12, 08:18 AM
kingnba6
kingnba6's Avatar
never had an eclipse unit. currently got a clarion nx500 and used to have a jvc double din but forgot the name of it
Old 02-24-12, 08:48 AM
88supramki
88supramki's Avatar
Eclipse is/was made by Fujitsu Ten, the same company that has been making Toyota Radios for the past 3 decades at least. What's nice is it's a single plug that runs from steering wheel to back of radio, no interface required
Old 02-25-12, 07:52 AM
Zorglub
Zorglub's Avatar
I don't wanna go with Eclipse for few reasons: i don't need GPS, i want a rotating volume ****, i want a flat panel to flush the dashboard and at least the last Eclipse unit is too expensive !
So probably go with JVC AV60BT unit
Old 02-25-12, 10:07 AM
88supramki
88supramki's Avatar
Eclipse no longer makes aftermarket radios. They are only OEM. The quality was far superior to JVC
Old 02-27-12, 11:37 AM
Zorglub
Zorglub's Avatar
Superior, i ll believe that for the price difference !
Old 05-11-12, 04:23 AM
Zorglub
Zorglub's Avatar
here a comparison between a IS200 and IS250 airbag. As you can see the ignitors are same size !
So with just a ignitor swap you can install a IS250 steering wheel in a SC300/400 with fonctioning airbag
Old 05-11-12, 04:25 AM
Zorglub
Zorglub's Avatar
now i have just to wire the radio remote (i have already change the illumination from green to white on them) trought the clockspring and use them with my JVC unit
Old 05-11-12, 05:33 AM
fazy_uk
fazy_uk's Avatar
Yeah the bag will swap no problem.
I am looking to do this myself when I get the chance. I really like the look of the later IS wheels.
Make sure you post pictures!
Old 05-11-12, 09:20 AM
Zorglub
Zorglub's Avatar
here are the picture of this wheel in my car, sorry is not a Lexus ;-)
Old 05-11-12, 09:56 AM
scENFORCER
scENFORCER's Avatar
Wow, that actually looks amazing. I thought it would look out of place..
Quick Reply: IS250 steering wheel in a SC400
