SC- 1st Gen (1992-2000)
IS250 steering wheel in a SC400
Old 05-11-12, 10:18 AM
fazy_uk
fazy_uk's Avatar
Agreed, that looks amazing. Given me a good reason to do mine now.
Thanks!
Old 05-11-12, 01:23 PM
INTIMAZY
INTIMAZY's Avatar
Hmmmm so does this mean ya need an is200/300 ignitor?
Old 05-11-12, 02:05 PM
MrCJ305
MrCJ305's Avatar
Nice I have the IS-F version in my SC which I re-did in all black because part of the steering wheel was blue. I haven't hooked up the air bag & horn yet though...Any luck with the horn & airbag?
Old 05-11-12, 02:07 PM
Zorglub
Zorglub's Avatar
horn and airbag would be easy to wire
Old 05-11-12, 02:14 PM
MrCJ305
MrCJ305's Avatar
Just making sure because I cut the plugs off of my old steering wheel but I'll figure it out somehow
Old 05-11-12, 02:19 PM
Zorglub
Zorglub's Avatar
airbag i a separate yellow cable. About the horn it's easy to find the good pin, try grounding each one in the black plug on the clock spring to find it
Old 05-11-12, 02:26 PM
MrCJ305
MrCJ305's Avatar
sounds good
Old 05-12-12, 05:07 AM
Zorglub
Zorglub's Avatar
i just check it for you, the horn is the last pin in opposite of the airbag plug
Old 05-12-12, 07:41 PM
MrCJ305
MrCJ305's Avatar
nice thanks man I appreciate it
Old 05-19-14, 08:41 AM
028's Avatar
wow
I'm looking into swap my es300 steering wheel with a later model wheel that has SWC,this thread helps a lot
Thank you
Old 05-19-14, 08:50 AM
tiguy99
tiguy99's Avatar
Same here! Would love to see one in a 1st gen. Sc
Old 05-19-14, 11:41 AM
jennie
jennie's Avatar
The IS wheel is nice because of the controls, but I like the wood steering wheels. They feel way nicer.
Old 09-20-14, 09:44 PM
gldndrgn14
gldndrgn14's Avatar
bringing back from the dead.
did you use the clock spring from the IS250 also to be-able to use the functions of the steering wheel buttons?
Old 09-21-14, 07:52 PM
Ali SC3
Ali SC3's Avatar
you use the clockspring of the wheel thats going on. what you change is the ignitor and sometimes the cruise lever will swap over to retain factory cruise. cruise might not swap over on these newer ones though.
Old 10-22-14, 11:08 AM
SEIDO
SEIDO's Avatar
Is that steering wheel, by any chance "smaller" than the OEM SC400 steering wheel?
Quick Reply: IS250 steering wheel in a SC400
