SC- 1st Gen (1992-2000)
Climate control questions/differences
Old 02-19-12, 11:57 AM
JOHIII
JOHIII's Avatar
Question Climate control questions/differences
I bought a climate control from pull a part and I don't remember what year SC I pulled it from. I don't remember if it was a 300 or 400 either. At the time I thought they would all work the same. I sent this one off the be repaired since the screen was blacked out. When I installed it in my 95 SC300, all the lights came on. all the buttons worked, beeped and everything. However it did not properly control my fans. It was either all or nothing. Also when I pressed the outside temp button it was blank. I sent off my factory one to be repaired and now it is installed and everything works. I would like to sell this other repaired unit but I don't know what it came out of or if the problems I was having were because of a bad climate control or just not having the right one.
It has a green display. The numbers on it are:
55900-24091
146430-3140
12V 91
Any info is appreciated.
Old 02-19-12, 12:17 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
You can swap the faces from 92-93 to 94-95-96, but not the brains.
Old 02-19-12, 01:37 PM
JOHIII
JOHIII's Avatar
So the one I have is from a 92-93? Can it be put in a 300 and a 400?
Old 02-19-12, 03:25 PM
Kalogerus
Kalogerus's Avatar
92-94 has green lights, 95-96 has orange lights. I assume u they're interchangeable between 300 and 400. Theres one way to find out, try it.
Old 02-19-12, 04:10 PM
CrazySC300
CrazySC300's Avatar
They're not as fully interchangeable as you think, the only climate control that will work properly on your '95 SC300 is another one off of a '95-'96 year model...hence the reason why you can't control your fan speed properly, The unit you have is likely from a '92-'94 unit.
Old 02-19-12, 08:12 PM
JOHIII
JOHIII's Avatar
Alright thanks. I just wanted to make sure it was a model problem and not a problem with the climate control itself. I didn't want to sell somebody something that wouldn't work properly.
CRybicki15
08-04-17 04:17 PM
flexnix
10-22-16 08:28 AM
Jasoneo5
01-28-04 08:50 AM
Quick Reply: Climate control questions/differences
