Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300
Sign in using an external account
Register Forgot Password?
Passanger Door wont open
Thread Tools Search this Thread Display Modes
Old 01-19-12, 02:27 AM   #1
Drifterkid
Trader Score: (0)
Scott Wedemeyer
Default Passanger Door wont open
My passager door wont open from the inside or out.. the lock button wont fully lock maybe half way and it seems like the door is locked or it wont fully unlatch... can you give me any ideas how to fix it or take the door panel off while the door is closed... thanks
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Drifterkid is offline   Reply With Quote
Old 01-19-12, 02:51 AM   #2
Cleanshots
Trader Score: (2)
Cleanshots's Avatar
Send a message via AIM to Cleanshots
cant take off panel with door closed unless you tear the panel off, like literally break it.. that just sounds terrible...
__________________
94 Sc300 Blk on USB 5spd 1 of 227 #076
2Jz-gte, Turbonetics T72-70, aeromotive, R154, BC racing, koyo, Act, HKS Hi Power, zirgo, TRS, Momo, Tial, BrianCrower, Fluidamper
Check out my threads and leave some love.
Stage1: Build and GTE Swap.
Stage2: Paint!
Ongoing Photoshoot Thread.
Cleanshots is offline   Reply With Quote
Old 01-19-12, 02:53 AM   #3
Drifterkid
Trader Score: (0)
Scott Wedemeyer
Hell ya it does is there anyway to get the door open
Old 01-19-12, 04:19 AM   #4
Justinizme
Trader Score: (0)
Sh0t By Justin
Quote:
Clean shots speaks the truth bro..
I had this problem about 2 weeks ago. Ended up being the door actuator went bad. Had to break/tear the interior panel to get access to the latch assembly
__________________
Justinizme is offline   Reply With Quote
Old 01-19-12, 11:22 AM   #5
speed6
Trader Score: (1)
i was on a cross country trip and the drivers door broke in Albuquerque, i live in so-cal. Had to dukes of hazzard it every time i wanted out.
I had to tear the top of the door off and then the bottom.
__________________
SC300, daily drift driver. 1994 5/MT 1/227-
speed6 is offline   Reply With Quote
Old 01-19-12, 04:18 PM   #6
Drifterkid
Trader Score: (0)
Scott Wedemeyer
i got my panel off without breaking it but how do i pop the lock
Old 01-19-12, 04:52 PM   #7
WadeLovell
Trader Score: (5)
There is, as I recall, a metal cable from the door handle to the lock. You separate the door handle from that cable and thereby from the lock and then open the door.
I called AAA for a lock-out service. They slim-jimmed the door lock. I got the panel off from the inside without damaging it but, crumbs, I did not take pictures. The statement above is what I recall doing but that could have been on something else. Anyone have the parts diagram?
WadeLovell is offline   Reply With Quote
Old 01-19-12, 04:53 PM   #8
WadeLovell
Trader Score: (5)
Anyone have a more detailed parts diagram?
Old 01-19-12, 05:02 PM   #9
Drifterkid
Trader Score: (0)
Scott Wedemeyer
how do i pop it then i can see the lock but i dont know where to pop the lock to get the door open
Old 01-20-12, 12:34 AM   #10
Josh400
Trader Score: (0)
Is the blue cable still attach to the lock? If it is, try pulling it. And while doing that pull the door handle at the same time. Hope that helps
Josh400 is offline   Reply With Quote
Old 01-20-12, 03:36 PM   #11
Drifterkid
Trader Score: (0)
Scott Wedemeyer
No is there a way to Manuel oPen the door I can see the door lock thing
Old 01-25-12, 12:40 AM   #12
speed6
Trader Score: (1)
i had to reach way back in the back and pop it out of the door lock mechanism to open it. once it's open you can re assemble ****. and order new yellow door lock rod clips from toyota too. if you bend the rod, you might be SOL.
__________________
Old 01-25-12, 01:05 PM   #13
AnonymousG
Trader Score: (2)
I dont want to make a new thread so I thought I would ask.
Has anyone made the exterior door lock work without the rod? My pass. side is missing the rod and its getting annoying having to lean over each time for a pass. to come in.
AnonymousG is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Passenger door won't open from inside or outside PJSC300 SC 400/300 19 09-30-13 08:54 PM
door wont open from outside door handle tonyzebra ES300 and ES330 15 08-22-12 04:40 PM
actuator broken dorr won't open even with key! rcolorado GS - Second Generation 9 06-21-12 04:02 PM
P/S FRONT AND BACK DOOR WON'T OPEN and LOCK markaus RX - First Generation 3 11-14-11 10:48 PM
door will not open from inside or out - i searched bryan767 SC 400/300 5 04-07-11 10:06 PM
Tags
1993, 1994, clip, diagram, door, es300, inside, jim, lexus, lock, open, panel, rod, sc300, sc400, slim, wont
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
